Old 05-20-2016, 11:02 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
Print Wikipost
mech. oil pressure gauge
Old 09-04-2010 | 11:03 AM
speedracer2536's Avatar
Default mech. oil pressure gauge
so i want to install a mechanical oil pressure gauge in my lt1 car.. i wanna put it on the pillar.. i have never installed one before though i know it cant be that hard.. just need some tips on routing the oil line to the pillar.. also is there a gauge that most people usse? any gauges to stay away from? i def. dont want a leak springing in my car..
Old 09-04-2010 | 11:12 AM
RamAir95TA's Avatar
It is ill-advised to run ANY fluids from the engine bay into the interior compartment. The proper way to do it is to use an electronic pressure sender.
Old 09-04-2010 | 11:15 AM
ahh ok.. well where can i find a gauge like that?
Old 09-04-2010 | 11:18 AM
RamAir95TA's Avatar
Autometer carries a ton of them. Jegs, Summit, site sponsors, etc.
Old 09-04-2010 | 11:30 AM
havent really found any through them..
Old 09-04-2010 | 12:51 PM
Badazz 97 TA's Avatar
whats wrong with the stock one?
Old 09-04-2010 | 01:18 PM
grn95t/a's Avatar
i am using this autometer electrical gauge...
http://autometer.com/cat_gaugedetail...earch&gid=2619
Old 09-04-2010 | 01:34 PM
PitchblackC3's Avatar
Formerly 99-2door-08/30/2010
Autometer alone makes about 30 different electric oil pressure gauges. Summit and Jegs both carry all of them.
Old 09-04-2010 | 02:44 PM
RamAir95TA's Avatar
That's what I'm saying. There are dozens available. Maybe you should refine your search techniques.
Old 09-04-2010 | 04:08 PM
SRZ's Avatar
SRZ
If you do decide to run a mech one, run it outside. Never run it fluids to the cockpit as others have said.
Old 09-04-2010 | 05:29 PM
SS RRR's Avatar
Village Troll
If you chose to run a mechanical gauge into the car, use steel braided line instead of the crap nylon line that comes with the gauge.
Old 09-04-2010 | 05:56 PM
idformula's Avatar
There's nothing wrong with a mechanical gauge, if you do run one, just be sure to run the line away from heat sharp edges, and where it can get pinched. A good trick to use is get the same amount of 1/4" vaccum hose and run it over the nylon line, this makes it more resestant to heat and sharp edges.
Old 09-04-2010 | 05:58 PM
SS RRR's Avatar
Village Troll
Problem with nylon line is if the oil gets too hot it can weaken nylon line to the point of starting to leak. A leak that can go unnoticed until you either have several quarts of oil on your floorboard or your engine dies.
Old 09-04-2010 | 06:05 PM
Speedy's Avatar
I use these gauges on a roof pillar. They change to all kinds of pretty colors LOL. Not a bad deal, they look good and they work.
http://www.glowshiftdirect.com/
Old 09-05-2010 | 12:53 AM
i refined my search techniques and found it.. thanks guys i have never looked into gauges before.. i wanna run a bigger than stock gauge in a single pillar pod just so i can have an exact reading in my face so to speak.. i dont wanna rely on the warning lights most times its too late when it comes on..
Old 09-05-2010 | 02:05 AM
airfix's Avatar
Whats all this talk about nylon line? That stuffs garbage. Use the copper tubing instead. I have a mechanical oil pressure gauge in my car (hvac panel) I see no issues doing this fuel I can see, but I feel a oil pressure gauge is safe to run inside the car. and I like having a mechanical gauge I dunno why just do. Anyways if you do go mechanical use the copper tubing instead of nylon, plus nylon tubing isn't allowed @ the track (NHRA Rules) Although I'm sure most tech guys won't look at that.
Old 09-11-2010 | 01:20 AM
kobraa's Avatar
I want to get an electric oil pressure gauge but have never installed them before...how do you attach the wire from the gauge to the oil pressure sensor behind the intake??
Quick Reply: mech. oil pressure gauge
