Great results!! 10.30's NA 385ci AI HCI Video Inside
Old 09-22-2010, 08:03 AM
  #61
ThreeHonks's Avatar
Originally Posted by quik95lt1
sorry i didn't see ur question.............yes its a full manual valve body but no its standard pattern........im goin low tens with the stock shifter
ok so you must have the trans go HD-2 B kit with vacuum modulator right?
what did you do to the shifter to stop it from moving into neutral on accident? so you dont accidentially hit neutral when you are shifting it forward into 3rd?
Old 09-22-2010, 08:29 AM
  #62
quik95lt1's Avatar
yes its that trans go kit but its modified a bit......give dana a call out at pro built autos in california and he can get you what you need to do it........heres his number......1-909-795-1876
hes very helpful and a great guy to talk to and deal with....
as for the shifter.......lol i didn't do anything to it.....im just careful with it like i said its a bone stock shifter.......for me it works fine.......took some getting used to but im fine with it now......i shift consistant with it no need for some crazy shifter IMO....but yea if you push it too far forward it will go into neutral.....gotta just remember that lol i did that once when i first put the valve body in it and ii tossed the motor up off of the rev limiter........xfi recorded 8450rpm lol oops
Old 09-22-2010, 12:05 PM
  #63
LS1 SPEED's Avatar
I think so too larry, im gonna be giving you a call for one of those LS1 Alternator relocation brackets. I'm tossing the PS pump and rack for a manual one.
COOL..just let me know
Old 09-23-2010, 10:31 AM
  #64
quik95lt1's Avatar
Default Round 1
Well just got in the first box......heres round 1 of weight reduction.......total is 53lbs off the nose infront of the wheels!!! Install pics this weekend
Removed the Front Bumper Support
Removed Sway Bar Brackets and Hardware
Removed Cruise Control Brackets and Hardware
Swapped out the 38lb optima red top for the braille 11 pounder
Removed the stock battery mounting tray and overflow container and replaced it with Braille 1lb aluminum batt mount and CSR Aluminum Catch Can
Total weight loss: 53lbs
Old 09-23-2010, 10:59 AM
  #65
Tireburnin's Avatar
53lbs is noticeable gain. Does the car sit a bit higher now?
Old 09-23-2010, 12:10 PM
  #66
quik95lt1's Avatar
not sure yet im working on it now lol......it may that is quite a bit of weight
Old 09-24-2010, 07:33 PM
  #67
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
Thanks!! It was great meeting you too....cant wait till next year.
Thanks, as did yours....congrats on your win too!!
you too tanner...yea the color isn't bad lol
it did i played around with the suspension and got it to hook hard in bg....made a 1.401 60' on one of my passes.....so with the good air up here in new england now and the weight i just pulled and hopefully getting the timing back in the launch im hoping for 10.20's if not high 10.10's before the end of the year. We'll see......
the shootout was awesome some great people down there........next year im taking that monday outta work so i can stay and party afterwords
do you ever come down to new england and race??
glad to hear it! New england, dam that is far from the detroit area. if there was a big late model f body that i fit into, i would consider it. i have a wife and 2 kids, they are the #1 priority, not the car. if you ever come a bit west to race be sure to let me know. never know how far i might go to t'n't. yeah you definitely made a trek from your hometown! i got off easy this year, my rtip was under 9 hrs.
Old 09-25-2010, 04:28 PM
  #68
94Z28rag's Avatar
Love the vids, Mike. Thanks for more motivation!
Old 09-25-2010, 04:46 PM
  #69
Moderator
BizZzatch350's Avatar
Bad *** set up!
Old 09-27-2010, 07:30 AM
  #70
quik95lt1's Avatar
yea it was a haullllll 18 hours from RI we drove it all in one shot on the way home......but yea ill definatly let you know if i ever end up closer to the MI area, next year i got 4 weeks of vacation so i'm gonna do some traveling and racing we'll see.....I'll let you know how I make out with the car....I'm expecting really good things with the suspension dialed in now and my future plans for it.....ill pm u my #
any time any time lol......keep workin on that thing i wanna see two low/sub 10 second lt1's at NED next year!!!
Originally Posted by BizZzatch350
Bad *** set up!
Thanks!!!!
Old 09-27-2010, 07:37 AM
  #71
quik95lt1's Avatar
Default Round 2
well i did the install on the battery and the catch can yesterday.......after dipping the front of the car in slim fast I managed to shave 63lbs off the nose all infront of the front wheels!!!!!
Now for Round 2 of Weight Reduction.....
Got a BMR Manual Rack on the way
Speed Inc LS1 Alternator Relocation Bracket
!Deleteing the Accessory Bracket off the front of the motor
!Swapping LT1 alternator for lighter LS1 alternator
Installing a set of Madman Travel Limiters
Fixed broken QA1 shock mount due to suspension hanging on launch
should be interesting.......cant wait to see what it does now!!!
hopefully track this friday if all the parts come in on time and i can get the toe aligned......
Old 09-27-2010, 11:25 AM
  #72
AChotrod's Avatar
Get to work and grab those 9s while the weather is great & b4 the snow flies!!!!
Old 09-27-2010, 12:05 PM
  #73
robsquikz28's Avatar
[QUOTE=quik95lt1;13916886]well i did the install on the battery and the catch can yesterday.......after dipping the front of the car in slim fast I managed to shave 63lbs off the nose all infront of the front wheels!!!!!
63 OR 53LBS IS ACTUALLY SHAVED OFF?
is the ls1 alternator a direct swap? what needs to be done if not?
Old 09-27-2010, 12:34 PM
  #74
quik95lt1's Avatar
[QUOTE=robsquikz28;13917847]
i got 63lbs off of it so far but after the ps swap and a few otha things im expecting to be in the 100-110 range.....100lbs should make a big difference espically being right off the front of the car....
as for the alternator not so much lol.....speed inc. makes a relocation bracket to mount the ls1 alternator down low on the motor like where the AC compressor goes....but then you've gotta ditch the accessory bracket and PS pump........im going manual so its no big deal.....but Speed Inc. does make a kit to move both the alternator (LS1 style) and PS pump....it looks pretty trick.....
I'll have some pics up later this week everything is coming in wed and thurs....
  #75
quik95lt1's Avatar
idk im shooting for 10.10's before the winter........the the winter the real fun starts......should come out running 9's next spring!!!
Old 09-28-2010, 07:59 AM
  #76
quik95lt1's Avatar
Default getting there
got the car stripped and cleaned up last night........painted a bit and tried to make it look a little better for now.......man i cannot beleive the space i have now with all that garbage gone!!! Plus now you can see the labeling on the Trick Flow "195cc" heads
Old 09-28-2010, 08:27 AM
  #77
joelster's Avatar
I have those same heads and they have no markings! WTF???? lol. I got mine when they JUST came out though (2005ish), so maybe they recently did that, who knows.
Take the fenders off and get the excess fender metal out of there. You can get 7lbs per side. While you had the front bumper supports off you should have trimmed the frame horns off. They are 6lbs each. Once you start you can't stop, lol. Door bars, rear seat brackets, rear stereo speakers, excess metal EVERYWHERE, etc, etc..... Get her down to fighting weight and you'll rip a 9 this year.
Old 09-28-2010, 07:29 PM
  #78
BADHAWK51's Avatar
looking good Mike.
Old 10-03-2010, 01:21 PM
  #79
Looking good Mike, I wanna see that alternator on there.
whats the part number on the coolant overflow tank?
Old 10-03-2010, 11:53 PM
  #80
94Z28rag's Avatar
I moved back down to PA, remember???
You'll have to come to Cecil, Maple Grove, or Atco to race with me now!
Quick Reply: Great results!! 10.30's NA 385ci AI HCI Video Inside
