drag strip friday
Now this is the help I need from you all . I am wanting to run low 7s on the motor. Is my set up closes? what can I do to get there? stroker kit ? Bigger cam for sure. single plane intake ? port the head ? Thanks
IMO I would sell the LT4 heads and get properly ported LT1 heads and complimentary cam, and put a single plane on it.
www.advancedinduction.com
We have a full CNC program for the GM LT4 head. We can also mock up and convert the head/manifold to work together at your specific deck height & desired chamber volume. Full CNC portwork, converting heads/single plane to work together, and porting of the manifold would typically be in the $1600-1800 range depending upon the amount of welding etc. we get into using your current components. Of course, we’re happy to quote you a complete setup if you need valve train etc. and can describe your goals. If you have questions or decide to move forward, we’ll be around. Thanks for your interest!
-Phil/Ron
Advanced Induction - Cylinder Head Development
704.918.5526 -- 6841 Belt Road, Concord NC 28027
-Phil/Ron
