Where to buy LT4 valve springs at for the cheapest?
Old Oct 11, 2010 | 12:58 PM
whytryz28's Avatar
Default Where to buy LT4 valve springs at for the cheapest?
I posted a WTB, looking for some used ones (this goes beyond budget build honestly lol) Also they will work with my stock LT1 retainers and locks correct
Anyways, where do i get some for pretty cheap? Thanks guys
Old Oct 11, 2010 | 01:01 PM
wrd1972's Avatar
Genuine LT4 valve springs might be getting scarce these days. IIRC I got mine many years ago at www.sdpc.com for around $40.00 or so. I used them with my LT1 retainers and locks with no issue.
Old Oct 11, 2010 | 01:03 PM
Bullit95T/A's Avatar
Try Competition Products for cheap springs
Old Oct 11, 2010 | 01:19 PM
whytryz28's Avatar
Found these from Pace
http://paceperformance.com/index.asp...D&ProdID=24732
Got a link? Im not sure what youre talking about.
Old Oct 11, 2010 | 01:55 PM
www.competitionproducts.com
Old Oct 11, 2010 | 10:27 PM
whytryz28's Avatar
Yeah found nothing.
So far Sdpc is the cheapest, do they have free shipping too?
Old Oct 11, 2010 | 10:50 PM
gorge's Avatar
this may sound like a stupid question, but what is the real diference between LT1 and LT4 valve springs? is it worth it to swap them? not the money but the time and work
Old Oct 11, 2010 | 10:52 PM
whytryz28's Avatar
Higher lift, need them if your going from 1.5 to 1.6 ratio rocker arms. Got my heads apart and they are worth changing to me since its all out of the car.
Old Oct 11, 2010 | 10:55 PM
LT1's Avatar
LT1
From what i understand LT4 is a good cheap cost efficient spring if you plan to only swap to 1.6RR or a low lift cam. $36.95 is not bad if you dont need more than .525" lift
Old Oct 11, 2010 | 10:57 PM
gorge's Avatar
cool cool, the heads still on my car but that isn't a prob for me, my car has 106k miles I think it might be time for new springs along with 1.6rr, that combination should make it worth the time right?
Old Oct 11, 2010 | 11:03 PM
gorge's Avatar
Im thinking of doing something cheap, found this oen for 150 bucks
.510 INTAKE LIFT / DUR.@.050 .230 DEGREES
.520 EXHAUST LIFT / DUR. @.050 .236 DEGREES
LOBE SEPERATION IS II0
I just want something mild, nothing special, if not that one maybe a copy of the LT4 hot cam, the guy that sells that first one sells the LT4 copy for 120 bucks, I just want to feel the car a lil bit stronger
Old Oct 12, 2010 | 07:02 AM
IF your goin to use that Ebay cam make sure to dial it in i bought one and found out it was reground and 4 degrees retarded also... so i gave to a friend to throw in a roller 305 block with vortec heads... it's a Will Hoite cam rite?
Old Oct 12, 2010 | 09:04 AM
gorge's Avatar
yeah, 4 degrees retarded, sounds good for me, I planing on running a 100 shot, does that mean that I don't have to tune the timing?
Old Oct 12, 2010 | 10:37 AM
kinglt-1's Avatar
I would not run a 230 236 grind w/ lt4 springs jmo...
Old Oct 12, 2010 | 01:21 PM
MasterTomos's Avatar
I looked into this earlier this year and it looks like the LT4 springs aren't the best choice for even a mildly cammed car. More than likely, you'll have to pick up some good springs from somewhere like comp if you plan on running an aftermarket cam.
Running LT4 springs with an aftermarket cam is almost like running 1.6rr's on stock springs, it's pushing it IMO.
Old Oct 12, 2010 | 01:36 PM
96lt4c4's Avatar
I have a used set that came out of my LT4 Vette without retainers. The had about 40,000 miles on them. I will sell them to you for $50.00.
Old Oct 12, 2010 | 02:04 PM
whytryz28's Avatar
PM sent
Old Oct 12, 2010 | 07:40 PM
96lt4c4's Avatar
replied
And yes you will need the LT4 retainers with the springs. The LT1's wont work. LT4 springs are bigger round.
The LT4 retainers are very light weight compared the the LT1's, so much that you can feel it holding them in your hand.
Old Oct 12, 2010 | 08:11 PM
96lt4c4's Avatar
LT4 springs were designed to handle the LT4 Hot Cam and thats about as big as you can go.
Old Oct 12, 2010 | 09:58 PM
defaultexistence's Avatar
Honestly the need for speed never ends ..and you would be happier in the long run with buying springs that don't need changed again when you decide that cam isn't gonna be enough for a fix next year...................
