Couple quick valvetrain questions
2) Can you just run 'hardened' pushrods with guideplates or do they need to be 'chromemoly'?
I'm asking this because I'm putting together a list of stuff to buy because I'm gonna be doing a cam swap through the winter.
I've already got Pro-Mag NSA 1.6 roller rockers, GM guideplates, and Comp 7/16" rocker studs here and ready to go. I've got my eye on a few AI cams but I haven't chosen one yet.
From what I understand I'll still need to buy pushrods, lifters, springs, possibly locks & retainers, and all the assorted gaskets and seals to do the job.
Any input is appreciated, thanks in advance guys.
2.) Hardened is fine - there is no absolute need for chromoly.
Any particular brand you or anyone else would recommend?
I originally was thinking about the Comp 918's but I've read a few threads with lots of complaints of them breaking at random.
$550 ---------Patriot Extreme spring kit
$37.18 -------ARP 7/16 rocker arm stud
$324.95 ------Ultra Pro Magnum 1.6
$25.95 -------trick flow guideplate
$86.95 -------trick flow chromemoly pushrods
$129.95 ------LS7 lifter
$395 ---------Ai Cam
Total price $1,549.98
The pushrod side of the rockers is not as important as saving weight on the spring side. The only real upgrade on the pushrod side is a stiffer pushrod everything else cost big money.
GM LS7 lifters sound good, and I found a good deal at thunderracing.com on the Patriot valvespring kit.
Just have one stupid question: what's the difference between locks and retainers? Im guessing the retainers are the round disc-like things that the spring sits on and the locks are what hold the retainers in place on the valvestem?
Don't worry guys, I'll have some good help with me while I do this swap lol. I can change an LT1 clutch with my eyes closed but have simply never had to touch the valvetrain or cam yet, let alone even take the valve covers off.
Lock
Retainer
Spring
Spring Seat
The lock locks the retainer to the valve stem.
Isnt chromoly know for being lighter weight and just as strong if not stronger than steel???????
Its still mass that has to be moved back and forth in position to do its job...and if its just as strong and lighter wouldnt it in turn do its job easier
Good list though.
