Bad gas mileage is it normal???
In a normal gear change you will see at most 1-2 mpg difference if any. With no other changes. This is a direct effect of the gearing. but what's it's doing is changing the amount of load as a condition of rpm changes.
Yes, load changes mpg. Yes, rpm changes mpg due to load. So in effect both are correct. This is why this argument is stupid. You are both correct to a point. Both ignoring the other half of the story to make yourself correct.
/thread
Then got my Impala. 3400SFI V6, limited to 105mph. I'd put it in cruise control at 105mph and lay back and relax. I'd do 80 where limit was 40.
I turned 20 and got tickets one after the other. Then accidents one after the other. Almost died man...have all the fun you want but just don't get yourself almost killed like I did.
Finally realized I just can't pay as much attention as I used to and I slowed down. Now I stick to 85mph in my Z28 on the freeway. Well, unless I hear 3 honks, but that's a different story.
jkjk but yea i get shitty mpg too, i shed tears of joy when i get 23 on the highway, and im just bolt on at the moment
