Help with EFI connection before start up
My tune file is to large but I can email it to anyone if they wnat to look at it and see if im safe to fire it up!
You can only change the injector to bank assignments (which is for closed loop fuel trims). This is not the same as firing order.
HP Tuners...
In their beta release they have the injector to bank assignment table.
Under Engine Diagnostics > General they have a Firing Order table (with no description for the table). Being under diagnostics, I would expect this to be related to misfire detection only, but they are leaving this up for interpretation and trial/error. Does this table really change the injector firing order? For both injectors and coils? Who knows? If it does, then HP Tuners is the only tuning software that allows the firing order to change at the calibration level.
LS1Edit...
Same as EFILive, but you may have to request the latest software update.
TunerCat OBDII...
Same as EFLive, but you may have to request the latest software update.
JET...
Not sure. I've not heard of anyone tuning with this equipment.
Here is how GM dealt with firing order and the 12200411 (LS1) PCM
The 24x systems (LS type engines) are pinned one way for injectors and 4x systems (Gen 1 SBC type engines) are pinned another way such that injectors 2&3 and 7&4 are swapped. In addition, GM changed the injector to bank assignment table (not the same as firing order) for proper closed loop operation. In other words, it's not wrong or a "hack" to change the firing order in the harness at the PCM. This is by (GM) design.
Recommendation
Compared to an LS1 PCM schematic (for example 2002 Camaro), swap injectors and coils 2&3 and 7&4, then update the injector to bank assignment table. Any doubts? Then copy/paste the 2002 5.7L Express Van injector to bank assignment table into your 24x LS type calibration.
Recommendation
Why am I changing the injector bank asignment from and LS firing order to an LT firing order?
LT1 Firing order 1-8-4-3-6-5-7-2
LS1 Firing order 1-8-7-2-6-5-4-3
Bank Assignment a-b-c-d-e-f-g-h
02 van bank asn 0-1-1-0-1-0-0-1
LS1 bank assign 0-1-0-1-1-0-1-0
Since im keeping the LS1 firing order in the PCM, the injector and coil wires for 7&4 and 2&3 are swapped at the pcm. wouldnt I want to keep the LS1 bank assignment?
LS1 Firing Order and LS1 injector assignent
0-0-0-0
1-7-5-3
1-1-1-1
8-2-6-4
LS1 Firing order with 2002 truck injector bank
0-0-0-0
1-2-5-4
1-1-1-1
8-7-6-3
The only way it makes sense to me is IF I only changed the coil pinouts and not the injector pinouts.
There were no mistakes in the information I posted above. Please use that information and then, if you are curious, data log in closed loop with the correct and incorrect injector to bank assignment table. I think that will help your understanding.
Even when I got it fire last night it sounded off like it wasnt running on all cylinders... I rechecked the ignition coils and they are wired in the LT1 firing order. right now when I turn it over itll pop a couple times through the exhaust and then after a couple tries itll fire up for about 2 seconds then die and no amount of throttle will keep it going. its like VATS is killing it but I checked that 100 times and its turned off.... I watched the injector pulse width whille starting and it doesnt cut out or anything...
RPM seems low when Im cranking 125-140RPM? Ive got two batteries hooked up and a battery charger so voltage shouldnt be an issue...
What I really need is someones working timing and fuel tables for E85...... Id just liek to check and see if im going in the right direction.... the popping in the exhaust is really bothering me... its almost like the timing is off and its igniting the fuel on the exhaust stroke....
