Tranny explosion
Broke the case and drive shaft and cross member and mangled the exhaust. Got it all apart today and checked the motor bell housing and flywheel. All good thank god. Done for the season. Will be ready for spring!!!
Sucks to hear about the trans mission going like that. But your car is ******* fast man! Gl getting it all repaired.
Denny's make a good nitrous shaft, or PST makes a killer alum 3.5" shaft, rated at 800-1000hp. Speed Inc had a GP on them a few months ago. Larry is running one, and he's in the mid 9's with it.
If he had had a truly stock driveshaft in it he would not have had it fail. The reason we swap driveshafts is because the stock one is balanced to a pretty low speed so 3.73 or better gears can cause a vibration.
