24x setup isn't running
Old 11-28-2010, 03:06 PM
S10Wildside's Avatar
The PCM calibration does not have a value for fuel pressure, so it can't be tuned for any specific pressure. The pressure has to do with setting the injector flow rate ( which I recommend be set as a constant across the MAP range for the TPI/LT1 fuel system).
It comes down to this. If your injectors flow 36# at LT1 fuel pressure then the flow rate in the PCM should be 36. But if your injectors flow 36# at LS1 pressure then the flow rate in the PCM will be much less than 36.
Old 11-28-2010, 03:29 PM
Phil'sC5vette's Avatar
Only basing it on the video, but it looks like the Base airflow minumim and the Startup Airflow need to increased slightly
On camed cars with startup tunes, I increase the Base Airflow Minimum 4G/SEC under 2000 RPMS, and on Startup Airlflow increase 4 G/SEC under 6.0 until the car idles steady.
Thats on LSx powered vehicles
Old 11-28-2010, 04:33 PM
camar0corey's Avatar
UPDATE: Yep car will stay running with constant throttle application.Tach reads 1k RPM I'm holding it at, who knows if that is right or double or what.
Old 11-28-2010, 05:49 PM
Doc has done several 24x conversions, I'm sure he has the tach calibrated correctly.
Old 11-28-2010, 05:58 PM
MattSapp95_T/A's Avatar
Have you tried adjusting the idle screw yet to around 900?
Old 11-28-2010, 06:16 PM
I dont suggest doing that. That simply tightens tension on the throttle wire. There are several sensors that come into play in start up, if the engine is hot, if it is cold, if it is in drive neutral, or in gear. If he goes WOT, and the cable doesnt recoil that extra 1/8th inch and the throttle hangs up, that could create a problem anywhere from stopping or hanging high RPMs on a new build.
The car can hold a steady RPM so its drivable. Granted it will stall at every stop, but it will cruise.
Its in the same family as NOT drilling a hole in the throttle blade.
To me, its just tuning etiquate
Old 11-28-2010, 06:36 PM
robsquikz28's Avatar
IT is in the tune for sure, unless you have a vacuum leak going on.. YOu will need to check for vac. leaks and make sure you have NO codes what so ever. Also for the throttle blades, dont open them. You will have to drill 2 small 1/8" holes in the blades. ONe on each side, but then again for your application. I wouldnt even do that since your on a small cam stock engine pretty much. Those are only done on bigger head/cam cars. As for this surging it can happen in just the tune if you reset your tps make sure your getting atleast 4.5v at wot with koeo. Also .67 at just idle with the blades closed and once again car turned off.
Those injectors are not that big off a issue to cause surging, Ive had and several others have been running 36 and 52s for years with no surging issues ever. Something like this though can definitely be in the tune. Since you didnt have the issue with the stock lt1 pcm
Old 11-28-2010, 07:14 PM
I'm going to try to make the drive tomorrow to EFI Alchemy. I'm hoping and praying I don't get pulled over in the process. Pretty much impossible to leave from a stop with no wheelspin right now.
Old 11-28-2010, 07:48 PM
If a tuner ever tells you they have to do this to your car, go to another tuner
Old 11-29-2010, 04:03 PM
qc97z's Avatar
Mine did the same thing...and my base tune was WAY off. Tune was fixed, and I was in great shape.
Old 11-29-2010, 04:05 PM
ThreeHonks's Avatar
make sure your injectors are wired right. You can get away with murder with injectors out of order
Old 11-29-2010, 05:07 PM
  #32
Really so I guess SPEED INC is a bad place to go huh
some of the fastest cars come out of there as for lt1 and lsx cars. ALso the fastest stock pcm lsx ever and others came out of there!
Old 11-29-2010, 10:28 PM
  #33
qc97z's Avatar
<----- Speed Inc tuned FTW!
Old 11-29-2010, 11:04 PM
  #34
Doc got it sorted out today! Long day though, three hour drive up, car had exhaust/intake leaks enough to make it angry, crashing computers, food, three hour drive back, coolant issue 10 minutes from the house for some reason after the car ran cool all day! I just got home around 11:45PM.
Old 11-29-2010, 11:18 PM
  #35
EFI Alchemy = Bad ***!
Glad Doc got you sorted out!
Old 11-29-2010, 11:33 PM
  #36
AZ2ENVY's Avatar
So what was the issues ?
Old 11-29-2010, 11:42 PM
  #37
It was sensors/tune related. I just had the unlucky draw in regards to guesstimating what was needed for the initial mail tune. Well maybe not entirely, once rolling the car ran fine, I just had that issue at idle.
Definitely thanks to Doc and crew at EFI Alchemy and also Phil for suggesting I try to drive the thing.
I have to go to sleep, way too long of a day!
Old 11-30-2010, 04:34 AM
  #38
Glad your home and the car runs better. Low end tuning is the hardest part of tuning, but once its dialed in, the car is fun to drive.
I dont care if they or anyother shop builds the next land rocket to the moon, if they are drilling a hole in your throttle blade to make it idle, they dont know how to use their tuning software.
Old 11-30-2010, 11:24 AM
  #39
Moderator
BizZzatch350's Avatar
It happens, I have gotten bad sensors right out of the box.
Old 11-30-2010, 05:29 PM
  #40
Wasn't really that sensors were bad, just had a hell of a time getting them to read properly at idle or get the numbers he was looking for on some sensors. My memory is garbage or I'd be more specific.
Quick Reply: 24x setup isn't running
