PICS of you guys running single plane setups
Intake: Professional Products Super Hurricane $250ish
Elbow: Custom built by a friend
TB: Summit 58mm $249
Fuel rails: Edelbrock (for the Victor E) $75ish
Fuel line adapters : can't remember, but they were $cheap
Work done by my friend to build elbow and machine the intake $300ish he used a 4bbl carb spacer with a vacuum port as the baseplate for the elbow. That way he didn't have to tap a vacuum fitting for the brakes and fuel regulator.
![](http://i9.photobucket.com/albums/a76/bigjoelster/cars/P6080316.jpg)
![](http://i9.photobucket.com/albums/a76/bigjoelster/cars/P6080319.jpg)
If you look at the thermostat area, you can see that he sawsall'd it off and filled the holes with weld, and then ground them smooth. It saves a little weight and cleans up the area a little bit.
