Car back from the mechanic - STILL won't shift while started
Alright how the hell do you remedy this?
I could be wrong but I if I remember correctly, last year when I was having similar trouble with my clutch dragging, someone, maybe wrd1972, told me that they were able to grind down the bottom of the 'T' that the fork pivots off of. That would draw the clutchfork's pivot point inwards away from the pressure plate.
I never had to do it myself so I have no idea how much you'd need to grind off to make it work. It just sucks because you simply can't grind down that retainer clip on the fork without destroying it, and you need it on there.
Hopefully someone who's tried this before will chime in, or better yet maybe someone with a better idea than me.
Keeping my fingers crossed.
Do you have a flywheel shim installed between the crank and the flywheel? If you do and its of excessive thickness, that would push the pressure plate and PP toward the rear. IMO, a flywheel shim is pointless following turning the flywheel because the hydros will adapt and set a new home position to work from.
So what else can push the pressure plate toward the rear? Grasping at straws here but thats where your at. Is the crank the OEM crank? Could the thrust bearing be so trashed that the crank is now sitting further toward the rear than it should?
So what can cause the fork to sit further toward the front? If the pivot points on the fork or T-fastener are so badly worn, I guess it could. Like SSRRR said, the fork not being properly set would screw things up to.
Regarding the T-fastener. The early Mcleod street twins had a release problem and the solution was a different bore master cylinder that provided more push to the slave thus making the PP open up more. This solved the release issue but now the fork would hit the pressure plate. Their solution to this was for you to machine .050" IIRC off of the bottom of the T-fastener to pull the fork toward the rear. I guess the Mcleod ST PP installed just naturally sits further to the rear than the OEM spec PP. I have never owned one but that just makes since.
Now back years ago when the clutch kicked my *** and I was grasping at straws too, I had the T-fastener machined down .050" and it did nothing for the release problem. Thinking about it now, cutting down the T-fastener cant do anything for disk release but it could do a lot for providing needed clearance between the fork and the PP if the two are making contact. I am still running that shortened T-fastener to this day with no known issues.
I am anxious to here if you have a flywheel shim installed.
Here's what I encountered with my pressure plate:
The points where it was ground is where it was making contact:
I'm telling you I fully believe your problem has been nothing more than the clutch fork not being pushed in all the way towards the TB.
I'm starting to think that grinding down the T is gonna be his only solution here. Grind down a little at a time, lots of trial and error. Unless someone can figure out exactly why his clutch and flywheel are sitting so close to the transmission, very strange.
Is this most likely all ONE related problem, or do I have two different issues occurring now?
And I guess the mechanic didn't install an adjustable master cylinder. He just extended the rod and pressed it back together. So I'll probably have to take the master cylinder out and do it right, but there's obviously another problem now.
So the problem has gone from the car not shifting while started, to the car not shifting while started AND the fork rubbing against the pressure plate.
