Need block.
Old Jan 3, 2011 | 04:40 PM
stevecritt's Avatar
Default Need block.
What all year model 350 blocks can I use. Do I have to have a 93/97?
Old Jan 3, 2011 | 04:43 PM
RamAir95TA's Avatar
Assuming you need an LT1 block, you need an LT1 block. All years are the same, just look out for the L99s. Corvette LT1s (and factory replacement LT1s) are 4-bolt main.
Old Jan 3, 2011 | 04:46 PM
AChotrod's Avatar
Where you at? I have a LT1 4bolt block for sale in IL
Old Jan 3, 2011 | 05:51 PM
stevecritt's Avatar
I live in nc. What are you looking for?
Old Jan 3, 2011 | 05:52 PM
stevecritt's Avatar
What its different about the lt1 block and other 350 blocks?
Old Jan 3, 2011 | 05:56 PM
96capricemgr's Avatar
Cooling system. On gen 1 motors the coolant goes into the block around all the cylinders and trickles up to the heads. IN an LT1 the coolant goes into the block but immediately makes a 90degree turn up into the heads and then around the chambers and back down around the cylinders and forward.
Old Jan 3, 2011 | 06:42 PM
stevecritt's Avatar
I know that about the cooling system but I was looking at a block and took my head gasket and it was all the same. It was a regular 350 block.
Old Jan 3, 2011 | 06:52 PM
RamAir95TA's Avatar
They are similar, but you can't put LT1 heads on a SBC block.
/story
Old Jan 3, 2011 | 07:55 PM
fex77k's Avatar
A few checks you can do is to; look at the front waterpump holes, if there is 4 on the sides of the timing cover and the top holes go up into the deck then you might have one. There is also a 327 stamped on the side of the block and they will never come with a mechanical fuel pump boss. It will save you a lot of time when looking at craigslist or junk yard "lt1s."
Old Jan 3, 2011 | 07:56 PM
stevecritt's Avatar
Ok well would it be cheaper to but a corvette 4 bolt or buy a regular 2 bolt and have it change over?
Old Jan 3, 2011 | 08:00 PM
AChotrod's Avatar
Not looking to ship it, sorry.
Old Jan 3, 2011 | 08:18 PM
Gojira94's Avatar
I live in Raleigh and am working on a car in Durham. Why do you need a block? Looking to get a rebuild on the quick or doing a 'steady as she goes' project?
I have a short block you could have for free. Problem is it's seized due to previous owner's negligence (overheated, blew head gaskets, hydrolocked). I haven't torn into it so I don't know if the rods are bent or anything else is trash (crank, block, main caps). I'm pulling it out this weekend, probably. Been prepping the replacement I bought.
So... it's yours if you want it; you can disassemble it and have it magnafluxed for cracks, deck it, bore it, and go for a nice 355 build. Or sell it for scrap if it's NFG. PM me if you want to talk about it.
