m6 to a4 how to keep my reverse lights?
hey guys i am currently in the process of converting over to a auto, and would like to know if anyone knows how to keep my reverse lights? thanks any advise would be appreciated!
that helps me out zero. lol
1. because autos are faster and easier on parts. ask me how i know.
2. i do alot of backing in spots at night. so without reverse lights i would be screwed.
http://shbox.com/1/1995_pcm5.jpg
24LT GRN (upper left quadrant, just right of the Parl/Neutral Position switch). You M6 PCM's program will need to be slightly modified to accept this signal...
lol yup a built 65e. i have most of the things i need, just want to figure out on these reverse lights lol. and yeah i am sure i wont regret it. mine is just a toy as well.
I attatched pics of the reverse light plug on the M6 and the shifter plug for the A4. The wiring for the shifter plugs is
A-ground
B-org/black wire to pcm for P/N idle signal pcm pin 15 connector C (gray/clear)
C-reverse light brown wire from M6 reverse switch
D-reverse light lt/grn wire from M6 reverse switch
E-starter yellow wire from M6 clutch pedal switch
F-starter yellow/brn wire from M6 clutch pedal switch
A-ground
