Is the voltage gauge accurate?
Old Jan 13, 2011 | 08:00 PM
Marc3.4V6's Avatar
Default Is the voltage gauge accurate?
I was wondering if the voltage gauge in the instrument panel is accurate? Mine usually starts just a little above half way but if I turn my lights on and/or plug my ipod in cigarette lighter and turn the stereo on, it dips below halfway but not into the red. If I turn the stereo off and unplug the ipod, it doesn't go back up. By the time I get home (35 minute drive) it's a little lower but still not in the red. Should I be concered? I put an optima redtop on 1 year ago.
Old Jan 13, 2011 | 08:03 PM
RamAir95TA's Avatar
It should be easy enough to determine it's accuracy using a DVM. I have found that mine is fairly accurate.
Old Jan 14, 2011 | 09:08 AM
curacaoz28's Avatar
^X2 mine works good, just measure it with a voltmeter
Old Jan 14, 2011 | 09:19 AM
iWon's Avatar
Maybe you should start looking towards your alternator? Same thing was happening on my car, turns out I needed a bigger ground.
Old Jan 14, 2011 | 09:50 AM
djjab57's Avatar
Originally Posted by Marc3.4V6
I was wondering if the voltage gauge in the instrument panel is accurate? Mine usually starts just a little above half way but if I turn my lights on and/or plug my ipod in cigarette lighter and turn the stereo on, it dips below halfway but not into the red. If I turn the stereo off and unplug the ipod, it doesn't go back up. By the time I get home (35 minute drive) it's a little lower but still not in the red. Should I be concerned? I put an optima redtop on 1 year ago.
Mine does the same thing ! I thought my alternator was going out for a couple of years before I quit thinking about it
Old Jan 14, 2011 | 07:49 PM
Marc3.4V6's Avatar
checked it, 12.3 off after sitting for a few hours, 13.4 running when my in car gauge says below half after driving 30 minutes. I thought it was supposed to be 14v engine running?
Old Jan 15, 2011 | 12:14 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm having the opposit problem with my 95. Granted it is a 3.4, but I'm having problems with too much voltage. My gauge reads very high and I keep losing all sorts of interior, exterior lights, my speakers, and radio.
Old Jan 15, 2011 | 09:54 AM
iWon's Avatar
Not sure on the exact specs, but it sounds like you may just have a funky gauge... your alt is definitely working
Old Jan 15, 2011 | 10:47 AM
Marc3.4V6's Avatar
thanks.
Old Feb 9, 2011 | 08:32 PM
Marc3.4V6's Avatar
FYI I got new thicker battery cables from innovative wiring and I get 14.3 volts when running now, and it feels more powerful too. It's a very finicky car though, it had already been running good, the new cables just made seem even more powerful, it maybe in my head, but the voltage increase is real.
Old Feb 10, 2011 | 01:07 AM
boostedlt1's Avatar
my gauge will start in the middle, then work it's way down to the red.
battery was just replaced and still the same thing. voltage while running is 14 volts at start up, then drops to 13.3-13.6 after running, yet gauge is in the red. i've just given up on it.
edit: also changed the 12 gauge stock alternator wire to a 6 or 8 gauge, can't remember, and added two more grounds, didn't affect anything
Old Feb 10, 2011 | 02:06 AM
SS RRR's Avatar
Village Troll
If you haven't already, take your alternator to Autozone to get tested. It's free. With the engine running voltage should be pretty much in the 14.5 range and the reading should be steady.
Old Feb 10, 2011 | 08:46 AM
quik95lt1's Avatar
i had a similar problem with mine and it turne out being a ground issue to the alternator..........i ran a 8 gauge wire from the alternator to the battery - post and bam 14.4V all the time even with a little 11lb race battery
Old Feb 10, 2011 | 12:37 PM
boostedlt1's Avatar
tested fine at autozone even put a different alternator on and still had the same problem.
put a ground wire from the alternator to the battery too
Old Feb 10, 2011 | 01:22 PM
quik95lt1's Avatar
^ check ur body ground from the battery to the chassis as well as from the battery to the engine block......
Old Feb 10, 2011 | 02:07 PM
boostedlt1's Avatar
checked those, they're tight, don't seem to be dried out/cracked, or corroded or anything. :/
Old Feb 10, 2011 | 02:59 PM
96azz28's Avatar
^^^ its an lt1 what do you expect lol jk
Old Feb 10, 2011 | 04:04 PM
boostedlt1's Avatar
lol nothing. that's why i leave it alone, it runs good, that's all i ask.
Old Feb 10, 2011 | 05:26 PM
fex77k's Avatar
Is the post on the alt tight? I had mine loosen up and it tested fine but would drop the voltage when driving.
Old Feb 10, 2011 | 07:00 PM
boostedlt1's Avatar
yeah it's tight
