ACs single digit build thread!
Old May 19, 2011 | 10:29 AM
  #161
AChotrod's Avatar
Originally Posted by robsquikz28
Ya me too and we can make some $$ on that biatch at SCC or RSD
Na LT1s cant go fast
Old Jun 9, 2011 | 02:05 PM
  #162
AChotrod's Avatar
Ok I finally put on the upper and lower A-arms. Took the car to the chassis shop and had a race alignment done and the car corner balanced.
Short block should be done early next week and I just ordered the new cam from Lloyd. Hopefully things will start happening pretty fast now.
Old Jun 9, 2011 | 02:14 PM
  #163
am_muscl's Avatar
^^ Where did you take it to get aligned? I know once I get all my front suspension stuff back on it will probably need one pretty bad...and what makes it a "race alignment", and what does corner balanced mean?
Sorry if these seem like stupid questions but I'm just trying to learn haha
Old Jun 9, 2011 | 02:23 PM
  #164
AChotrod's Avatar
TFworks in Arlington Heights did the work. Good guys and they did the front and rear alignment for 90 bucks, and its all tubular adjustable. They set the front suspension so when the car is accelerating in a straight line the front tires are straight up and down. Not recommended for a DD but since my car see little street time I set it up for drag racing. More info in the drag racing section if you do a search there.
Corner balance is getting the cars weight as even as possible on all 4 corners. Its tuf to do front to rear without rear coil overs. But they did get the car from about 125lbs heavier on the PS to 12lbs dif side to side. Im happy with that. Corner balance was 100 bucks
Old Jun 11, 2011 | 09:28 AM
  #165
joshh123's Avatar
what cam did LE give you?
Old Jun 11, 2011 | 11:33 AM
  #166
AChotrod's Avatar
just a little 244/254 608/608 110lsa
Old Jun 11, 2011 | 11:49 AM
  #167
robsquikz28's Avatar
lil cam, thats pretty damn big. 9s here we go
Old Jun 11, 2011 | 12:34 PM
  #168
BADHAWK51's Avatar
That cam is still just a little smaller than the one I'm running.
Old Jun 11, 2011 | 12:50 PM
  #169
Colin91Z's Avatar
***** weak, son. The cam Lloyd sent me a few weeks ago is 258/266 @.050, .680/.688 lift, 106 lsa
Old Jun 11, 2011 | 01:00 PM
  #170
BADHAWK51's Avatar
Originally Posted by Colin91Z
***** weak. The cam Lloyd sent me a few weeks ago is 258/266 @.050, .680/.688 lift, 106 lsa
Haha ya, but your a solid roller thats a big difference.
  #171
joelster's Avatar
You should have waited a bit on the cam. The motor I bought has a cam in it that i'm not going to use. I would have sold it to you. I know the duration is 247/254 and it's on a 112, iirc the lift is .625 or.630, somewhere in there. Small base circle too. As soon as my new cam gets here, this little peanut stick is going up for grabs!
Old Jun 11, 2011 | 01:04 PM
  #172
joshh123's Avatar
nice.. here is mine.. we have somewhat of a similar setup. just wondering what yours will run.. my is in a vette so i will never see its true potential.
Old Jun 11, 2011 | 01:06 PM
  #173
Colin91Z's Avatar
yeah I know, I was just tryin to stir AC up a bit
Old Jun 11, 2011 | 01:14 PM
  #174
BADHAWK51's Avatar
Collin, how is the new setup coming along I haven't heard anything lately ? I sent the converter out on my car hoping you will have to run me down with that big cube SR monster.
Old Jun 11, 2011 | 01:26 PM
  #175
Colin91Z's Avatar
Its getting closer. Been taking longer than it should because we've been working on our 3rd gen for Street Stock too. Should have the 392 up and running in the next couple of weeks though, its got a date with the tuner/dyno at the end of this month
Old Jun 11, 2011 | 01:33 PM
  #176
AChotrod's Avatar
its a "street cam" lol. Without changing the PCM going bigger wont make any difference. This should pull to 6800-7k.
Old Jun 11, 2011 | 01:35 PM
  #177
joshh123's Avatar
i think it will have better manners then you would think. mine does anyway.
Old Jun 11, 2011 | 01:38 PM
  #178
AChotrod's Avatar
Im sure it will. How do you like that 107lsa? Should sound pretty nasty.
Old Jun 11, 2011 | 01:41 PM
  #179
BADHAWK51's Avatar
Good to hear, but with your's and Ac's build I'm feeling a little down for this race with the finances not being there to make some changes to the car I wanted to this year.
Old Jun 11, 2011 | 01:42 PM
  #180
97LT1's Avatar
Ac why dont you upgrade brakes to LS fronts at least? Stock lt1 brakes suck, and your going to be going fast.
