ACs single digit build thread!
Yep TH350 built with a JW ultra bell RMVB, B&M pro ratchet and a Neil Chance
4k+ stall
. I decided to go 50-300 to be safe for now but can always change them out later if Im feeling crazy. My noids are good to 500, but I figured 100hp hit will change the car too much while Im getting it sorted out. Also my Nano will only support a 250shot without stepping it up to the 4500psi kit.
On a 300shot the car will make around 750rwhp and that should be good enough for a while.
Also got an update on the short block. Block is getting worked on now and should have it within 2 weeks.
