ACs single digit build thread!
Old Jan 15, 2011 | 08:03 PM
AChotrod's Avatar
Default ACs single digit build thread!
So I figured Id put up my single digit goal build for this winter. Engine will be a 383 LT1 stock block, half fill, splayed mains, SRP forged pistons,Eagle H-beams, eagle forged crank(already at the machine shop) 12.9:1 compression with stock ported heads/ intake HR cam. Ill be using my Lloyd Elliott ported current heads/intake and a new LE custom cam for the 383. Short block built by Speedinc and tuned by Speedinc!!! FTW!!!!!
Trans fully built RMVB TH350 with JW bell with a NC 4000+ stall and B&M stealth pro ratchet shifter.
Car sits at 3500 with me in it now but ill be taking out some more weight.
Chassis is fully done until I need a cage or till the tracks kick me out. UMI K-member, upper and lower a-arms, Strange DA front shocks with 300# springs, BMR sub frame connectors, Wolfe 6point bar, UMI TA, UMI LCAs, UMI PHB, UMI LCA relocation brackets, UMI trans cross member, UMI drag bar, Madman AFCO rear Shocks, Stock rear springs with heater hose mod, Dana S60 rear end 35 spline axles and 4.10s.
Wheels are Dragstars with MT sportman fronts and 275-60-15 MT ET drag radials out back
Nitrous kit is a Nitrous Outlet LT1 specific plate kit, Stand alone fuel system, progressive contoller, NANO, MSD dig 6. With all the goodies.
LOTS HAVE CHANGED SINCE THIS POST SO READ ON IF YOU WANNA KNOW.
Ill update as things go!
Old Jan 15, 2011 | 08:08 PM
vtec's Avatar
Resident Racing Jerk
should be good to get into the 8's if you can lose some of that weight.
Old Jan 15, 2011 | 08:14 PM
AChotrod's Avatar
With some more juice I think your right but would require a DP system. I still have alot of weight to pull. Car still has airbags, stock brakes, front speakers bumper supports etc.
Old Jan 15, 2011 | 08:21 PM
vtec's Avatar
dp? donkey punch?
Old Jan 15, 2011 | 08:22 PM
stevo9389's Avatar
RMVB FTW! driving with one was almost enough to make me consider swapping out the t56.
Old Jan 15, 2011 | 08:25 PM
AChotrod's Avatar
Originally Posted by vtec
dp? donkey punch?
lol direct port system or change to a single plane intake and a plate kit.
Old Jan 15, 2011 | 08:29 PM
Carter01's Avatar
AC, looks awesome as usual. I would expect no less!
Did you get any passes in on your current setup with the nitrous?
Old Jan 15, 2011 | 08:40 PM
AChotrod's Avatar
Thanks,
Na i couldnt make it out. Although Im guessing it wouldnt be far off my current goal.
Old Jan 15, 2011 | 09:38 PM
djjab57's Avatar
as always you inspire me, My build will be done & in the car VERY soon !!!
Old Jan 15, 2011 | 09:42 PM
robsquikz28's Avatar
I cant wait to see this car out this year!!!!
IM so jealous
Old Jan 15, 2011 | 09:46 PM
AChotrod's Avatar
Heres the 383 i got never ran b4. Then I I tore it down to build it the way I wanted.
Old Jan 15, 2011 | 09:50 PM
Mike what pistons are those -5cc?
what rings are you gonna use?
whats the compression height on them?
Old Jan 15, 2011 | 09:52 PM
AChotrod's Avatar
yes -5cc Same builder that does Z8s motor is specing the rings
Old Jan 15, 2011 | 09:54 PM
Lawhead's Avatar
Car will look exactly the same but have the TH350 and a 383 bottom end.
What do you guys think???
Where does the cat go in this build ???
But man that looks like a nasty build wish I could do something like that :/
Old Jan 15, 2011 | 10:01 PM
AChotrod's Avatar
I deleted the cats so no worries man!
Old Jan 15, 2011 | 10:02 PM
Lawhead's Avatar
Clever to say the least!
Good luck with your goals!
Old Jan 15, 2011 | 10:11 PM
do you know the part number on the pistons??
hellfires?
edit: got the # and its a 1.125 ht..not bad for spray but could be better!
Old Jan 15, 2011 | 10:15 PM
AChotrod's Avatar
They will meet my goals! Not using hellfires.
Old Jan 15, 2011 | 10:27 PM
then what???
Old Jan 16, 2011 | 01:12 AM
Mighty Whitey's Avatar
Looking good!
Glad to see you have all the chassis mods done before you decided to dive in to the motor. I think I'm going to work on some suspension parts before I even do a cam swap this time around.
Keep up the good work, you should have no trouble hitting your goals.
