375hp? +/-
Old Jan 28, 2011 | 06:54 AM
pillarpod's Avatar
a custom cam is the way
Old Jan 28, 2011 | 07:00 AM
fuzzyjk's Avatar
I would be happy with anything better that a 12.2.
The reason I went with the 227 was for the stealth effect not for all out power.
Old Jan 28, 2011 | 07:30 AM
96capricemgr's Avatar
Like I said, the 227 is a torque cam, the goobers comparing it to the HOT cam are forgetting the HOT is a HP cam.
I am not saying the 227 is a bad choice, it is mild and proven will run well a LONG time before wearing out a spring like the 918.
People are also inflating your numbers because they put undo faith in Lloyd's magic.
Old Jan 28, 2011 | 11:22 AM
gregrob's Avatar
Duane you are misguided. You do realize a set of LE1s has been over 400rwhp right?
I BUILT a car with cam similar to the 227 with more lift. 411 rwhp all day long.
Old Jan 28, 2011 | 12:40 PM
dlozSS's Avatar
I have a very similar set up that im working on my 97ss, LE1 heads n 3600 stall as well...should be getting a dynotune in about 2 weeks when I put the block back in n ill post my numbers
Old Jan 28, 2011 | 01:16 PM
The good(not Lloyd's) ported LT1 stock castings have been over 500rwhp on multiple cars even through automatic transmissions and 9". That does not mean every instance of their use is 450+rwhp.
But hell you are so stupid you can't spell something written right in front of you so I guess I am stupid for even trying to reason with you.
Here is a post about actual results with LE2s and the similar Lingenfelter 211/219 cam, the Lingenfelter actually has a bit more lift. http://camaroz28.com/forums/showpost...29&postcount=1
Show me an example to suggest I am wrong.
Old Jan 28, 2011 | 01:41 PM
WS Sick's Avatar
B&M = Break and Mangle.
The cheap converters create ALOT more heat and over time will eat a tranny as everyone knows heat is a trannies poison.
I would not use that cam if I was wanting 375 RWhp.
Old Jan 28, 2011 | 02:46 PM
fuzzyjk's Avatar
Looking for 375 crank HP.
Old Jan 28, 2011 | 02:49 PM
Lawhead's Avatar
Originally Posted by 96capricemgr
the good(not lloyd's) ported lt1 stock castings have been over 500rwhp on multiple cars even through automatic transmissions and 9". That does not mean every instance of their use is 450+rwhp.
But hell you are so stupid you can't spell something written right in front of you so i guess i am stupid for even trying to reason with you.
Here is a post about actual results with le2s and the similar lingenfelter 211/219 cam, the lingenfelter actually has a bit more lift. http://camaroz28.com/forums/showpost...29&postcount=1
show me an example to suggest i am wrong.
all hail ai!!!!!
Old Jan 28, 2011 | 03:13 PM
gregrob's Avatar
Do wayne
Old Jan 28, 2011 | 03:37 PM
How about that example I asked for?
Old Jan 28, 2011 | 03:47 PM
  #32
gregrob's Avatar
Just wait til he dynos it
Old Jan 28, 2011 | 03:50 PM
  #33
Lawhead's Avatar
I had AI in consideration BIG time until an email I relieved from them you can't argue there results. But after what was said........I'll like spending my money else where.
Old Jan 28, 2011 | 04:20 PM
  #34
Again back on target, I sited a comparable example that fell short of even my prediction and you guys are blasting my prediction as too low. Show me what you are basing your guess on.
Old Jan 28, 2011 | 04:28 PM
  #35
Lawhead's Avatar
https://ls1tech.com/forums/lt1-lt4-m...o-results.html
Something like that?
Old Jan 28, 2011 | 05:09 PM
  #36
RamAir95TA's Avatar
Funny when LE guys cry when AI tells it like it is, especially when they know nothing about either one.
I could care less about the cushy feeling Lloyd gives you guys on the phone or through email. I'm after REAL results, and that's all there is to it. It's a shame that 400whp is so commonplace for LT1s nowadays. So common it just isn't impressive anymore.
Once again Lawhead, you're quick to side with LE and bash AI when you have no real-world experience.
Old Jan 28, 2011 | 05:21 PM
  #37
Originally Posted by Lawhead
Are you actually so retarded you are sighting a Comp 306 example when the OP is asking about a Crane 227? You sighted a cam with 20 degrees more duration, I sighted one within 1 degree on the intake.
Just to be clear I am not saying the 227 is bad, it is mild and that is what the OP wants, that is fine so long as expectations are realistic which I think his NA expectations are but I don't think he will hit his goal on boost.
Old Jan 28, 2011 | 05:23 PM
  #38
Lawhead's Avatar
I have not once bashed AI until they said what they said to me
Every time someone comes on here asking I mention both companies and even after what they said to me I said they perform theres no doubt about that
and have you ran the LE's??
Old Jan 28, 2011 | 05:26 PM
  #39
Also the example you sighted was an M6.
Old Jan 28, 2011 | 05:28 PM
  #40
fuzzyjk's Avatar
Will 20 degrees work out to a 83 whp difference? I don't know **** so I am looking for education not trying to bash. I know the M6 must be 20 or so HP right?
What will I need to do to I see a 12.2?
