Power gains from a 52mm - 58mm tb on a H/C car?
So I've got a 58mm BBK on my car currently, but I'm interested in getting a Holley tb because they look so much nicer and would go with the rest of the engine. I found a great deal on a 52mm one.
So is there really much of a power gain between the 52mm and 58mm on a H/C car? Should I wait for a 58mm?
Slim to none. If you have money to burn go for it. Alot of the time aftermarket 58mm throttle bodies have IAC, TPS range and idle control issues., but I didn't have any of those issues.
Having said that, I went with a Holley 58mm on my 383 with minor issues, easily fixed. I ran a Holley 52mm for 6 years prior though.
If your search, there is a thread where a guy did a dyno comparison between the two. He had a mild H/C setup and put down high 300's. Peak numbers were slightly more with the 58mm but the graph showed gains of up to 20ft/lb under the curve.
