Opti Eliminator preview...
Opti as a dist has no issues, its the bullshit sensor that is the problem. This system along with a modded PCM to get >7kRPMs and I would be golden
. Opti bearings **** out all the time from rpm, but you know more than me. I see it as pointless to retain the opti and only have 1 coil. Hell LTCC is cheaper than this and does the same thing plus 2 step and timing retard. What the **** do I know though....
This will be a nice, low cost alternative to the EFI connection stuff if it pans out. Biggest tradeoff is still being stuck with an ancient PCM.
I've thoroughly priced it out since I was planning on running it, and what you are arguing is not feasible.
Not to mention that by the time you have an engine where you should start looking at opti alternatives and alternate computers, one grand is a drop in the bucket. Not much more then a decent cam and set of lifters for a SR build.
Good question.
If you can get this to work along with the modded computer as a kit for under a grand you would have a huge hit. I can say for sure that I'd get one.
What harness mods would be needed? I'm assuming that at least the first few versions would be more cut/splice then plug and play.
Good question.
Since when does engine level have to do with opti failure? I've never heard of one of those going on a stock motor
Alas, I yield to your overwhelming expertise and return to the rock I crawled out from. I shall look for a drop in the bucket too unless you have some to spare?
Don't get me wrong here I think its fair pricing and cool that you are trying to develop something for us but I really don't see what you are fixing and wonder what issues you will run into if someone's balancer hub wasn't installed correctly for tdc.
Where did I say rotor? You get bearing end play which triggers the self-destruct mode. I don't remember seeing an opti sensor on my buddy's efi setup
