LT1 Crankcase Vacuum Pump Kit in Development
Old Feb 21, 2011 | 09:25 PM
Ralls's Avatar
Originally Posted by 97Z28SS
Great because I'm not running the LT1 ignition anymore, I have the EFI Connections 24x kit with 8 LS2 coils. Do you have a pn for the street vacuum pump kit that mounts to the drivers side head and maybe some pics, thanks?
Um there are 2 different brackets. Go to GZ Motorsport's website and it describes everything and has pictures. A head mounted vacuum pump is the most popular so many companies have it. Look into Star Machine and Moroso too.
Originally Posted by Marc3.4V6
Hmm, I'd need to know more about it for a daily driver, but I do have all AC removed except for the pulley, as I never did get the delete pulley for it. So it would work for me.
Having one on a daily driver is ok. You will most likely have it cycling oil through the pump for a mild performance street engine. There are different ways of doing things depending on how extreme your engine is. I'm no expert though. I'm just trying to get this kit made.
Old Feb 21, 2011 | 10:33 PM
Tensec94z's Avatar
Here is my setup.
Old Feb 21, 2011 | 11:46 PM
fex77k's Avatar
Originally Posted by Tensec94z
Here is my setup.
I want to see more pictures of your setup.
Old Feb 22, 2011 | 08:28 AM
quik95lt1's Avatar
Originally Posted by Wicked94Z
yes, but they're not meant for a daily driver type. They build a lot of heat in the pump depending on how much vacuum you're pulling, and how long/hard (yes long and hard ) you're running them. The biggest benefits are seen when you're running an appropriate ring package, and pulling say 15+" or so. But at that level you're looking at wristpin problems (lack of oiling) with extended run time, and sucking a substantial amount of oil out of the crankcase. At lower levels of depression you'll still see benefits, but for 800 bucks I can think of quite a few alternatives on a street car.
not quite dude........i ran a vacuum pump on my car since day one........pulled 15+" out of the crankcase at WOT and never had an issue with anything......the pump still runs great and upon the tear down i have no wrist pin or oiling issues........also with proper baffling and bleeding of air you will not suck up that much oil at all..........I've had great luck with the GZ pump on my car........
Old Feb 22, 2011 | 09:50 AM
ZGOBYBY's Avatar
Here is my setup.
That's a great looking set-up right there.
Old Feb 22, 2011 | 01:54 PM
SRZ's Avatar
SRZ
Here is my setup.
Damn,......nice! Thanks for the pic!
Old Feb 23, 2011 | 05:01 PM
Ralls's Avatar
I was hoping by now someone would pop their hood and stick a measuring stick down there
Old Feb 23, 2011 | 05:20 PM
ThreeHonks's Avatar
sorry i cant help ya, I have a low mount alternator.
Nice to see some new innovation though! good idea, keep with it despite the neigh-sayers
Old Feb 23, 2011 | 10:15 PM
fex77k's Avatar
This is a terrible picture, but it will get you an idea. from the center of the top bolt on my a/c delete pulley to the top part of the frame rail I had just over 3in, to the rail. The red line represents the rail.
On the underside of the car, I have the tape measure pressed against the rail and I have the lower bolt right around 4.5in.
Old Feb 24, 2011 | 03:48 PM
Ralls's Avatar
Thanks fex77k, that's exactly what I needed. I'll pass on the information.
Old Mar 1, 2011 | 10:11 PM
Ralls's Avatar
Does anyone know if they make a 6inch crank balancer that fits an LT1???
We're still working on how everything is going to mount. We may put the vacuum pump in the stock alternator location and the alternator where the A/C is.
Old Mar 2, 2011 | 12:11 AM
  #32
SRZ's Avatar
SRZ
ATI does, it may have been 6.25 or 6.50 but I've held one in my hand many yrs ago.
Old Mar 2, 2011 | 07:44 AM
  #33
Ralls's Avatar
Yeh ATI is all I can find. The smallest LT1 dampener on their site is 6.78". Not sure if that is small enough.
Old Mar 3, 2011 | 08:06 PM
  #34
Ralls's Avatar
I need to know how far the center line of the alternator pulley (in stock location) is from the top underside of the hood. I realize this is very difficult with the engine actually in the car. So I was able to get inside the engine bay and close the hood, then measure from the top of the frame rail to the hood. That will be our common reference point.
Can somebody please measure from the CENTER of the alternator pulley to the top of the frame rail??
With that information, I can determine the distance from the alternator pulley and hood. Thank you
Old Mar 7, 2011 | 08:50 AM
  #35
James Montigny's Avatar
It's about time someone built a kit for the Lt1.
Old Mar 7, 2011 | 04:30 PM
  #36
fex77k's Avatar
Tape measure is on the rail.
My motor has brand new motor mounts on it, so my motor will sit as it should from the factory.
  #37
Ralls's Avatar
Well it seems putting the vacuum pump where is A/C was is no longer an option. Too complicated.
Last idea is putting the vacuum pump where the alternator was. This is still a good option because there is enough room for their larger pumps. You would only need to relocate your alternator. Good thing is any alternator relocation will work if it still has the top of the accessory bracket. You can even keep A/C.
The vacuum pump will have to be mounted a little higher than the alternator was so I'm still not sure it will fit under the hood. I won't know till someone measures from the alternator pulley to the frame rail.
Old Mar 7, 2011 | 04:33 PM
  #38
Ralls's Avatar
fex77k to the rescue again!
What is that, 10 inches right? Maybe a little less?
Old Mar 8, 2011 | 12:39 AM
  #39
fex77k's Avatar
More like 9.5. That is a stock alt.
Old Mar 21, 2011 | 07:41 PM
  #40
Ralls's Avatar
We were able mount the vacuum pump where the alternator was. It should be an easy bolt on deal. Just need to relocate the alternator and have a smaller crankshaft pulley. I have the bracket and pump being shipped to me now. I'll let you all know how it goes.
