LT1 Crankcase Vacuum Pump Kit in Development
http://www.turbobuick.com/forums/gen...-pump-how.html
This billet 7.5" pulley may or may not be able to be used. I got it anyways just to see if it will fit without hitting things like the hood or power steering pump. I'm pretty sure it will hit the power steering pulley though. The other pulley option is a 5.7" smog pump pulley that can be bought at any auto store for $20.
Here is a comparison of the alternator and vacuum pump:
The vacuum pump sticks out LESS than the LT1 bracket, whereas the alternator sticks out a few inches. The AN fitting isn't screwed in all the way mind you. Point is, people should be able to use tall valve covers without hitting the pump!
I'm going get started on modifying the accessory bracket for the alternator relocation.
All I had to buy was a 1-1/2" angled aluminum 1/8" thick piece from home depot and one nut & bolt.
Any alternator relocation will work as long as you still have a way to adjust the belt. Just ask if you have any questions on how I did mine.
I still haven't figured out the belt length. It's going to vary from car to car depending on where you mount the alternator. I could tell you what length it is if you mount the alternator like I did.
I had to throw in a few pictures of my new motor
Taller valve covers will easily clear (the AN fitting is off to the side).
I was trying to get a belt but I can't find any local at all... only on summit racing. It needs to be a little longer like 64.25in or 64.5in.
The only thing I'm not 100% positive on, is whether or not it will clear the hood. If my measurements are correct it should clear. I need to put the motor in just to be sure.
I double checked some measurements and found out it should clear the hood no problem. It actually came out to be like 1/8" lower than the stock alternator height.
I'm going to find a machine shop around here that can replicate this vacuum pump mounting bracket for those interested in this setup.
The pump I used is from GZ Motorsports. Part number VP101A. I would not recommend getting VP102. It's the same pump but puts the exhaust outlet fitting in a place that might hit the accessory bracket. You might be able to use a 45* fitting to make it fit but I would just use the VP101A.
Sorry I have not found anyone to duplicate the bracket yet. It's kinda hard when all the shops are only open when I'm at work myself. I'll try harder guys.
I got my new valve covers in the mail and some more AN fittings. Next step is to powdercoat all those scratched up black parts
