LT1 Crankcase Vacuum Pump Kit in Development
The pump I used is from GZ Motorsports. Part number VP101A. I would not recommend getting VP102. It's the same pump but puts the exhaust outlet fitting in a place that might hit the accessory bracket. You might be able to use a 45* fitting to make it fit but I would just use the VP101A.
Sorry I have not found anyone to duplicate the bracket yet. It's kinda hard when all the shops are only open when I'm at work myself. I'll try harder guys.
I got my new valve covers in the mail and some more AN fittings. Next step is to powdercoat all those scratched up black parts
Oh well.. so to answer your question they are $60 valve covers from ebay. The quality is amazing. I've had canton's before and these are just as nice.
I don't expect this pump to not be able to pull enough vacuum. In fact you need to use a regulator to keep it from pulling TOO much. Do not go over 15" of vacuum. I'm going to set mine to 12". That colorful red & blue **** is my regulator. I bought it from STAR Machine because I like their regulators better. I also bought their -10AN bung with baffle (on valve cover) and their bolt-on oil fill cap.
Actually, call up GZ Motorsports and see if they will make this bracket for you. I donno if they kept a template or not. They didn't sound interested in making a bunch of them but it's worth a shot. Just ask for Greg Zucco and mention my name "Ralls."
-GZ Motorsports Vacuum pump (VP101A)
-Dorman 5.69" vacuum pump pulley from local parts store (300-912)
-Custom vacuum pump bracket
-ASP 5.7" crankshaft balancer (ASP945100)
-ASP smaller alternator pulley
-Custom alternator bracket
-Stock length serpentine belt
-Star Machine -12AN Female vacuum regulator
-Star Machine -10AN fitting w/ baffle for valve cover
-Moroso breather tank (85402)
AN Fittings:
-12AN X 1/2" MPT 90 degree (out of suction side pump)
-12AN nut X -10AN male swivel reducer (after regulator)
-10AN straight pushlock hose end (after reducer)
-10AN 90 degree pushlock hose end (valve cover)
-10AN X 1/2" MPT 90 degree (out of exhaust side of pump)
-10AN 90 degree pushlock hose end (off exhaust fitting)
-10AN 90 degree pushlock hose end (off breather tank)
-10AN push lose hose (4 feet depending where you mount breather tank)
So that is everything I used. You can do whatever fittings you want. The only reason I mixed -10AN with -12AN is because I had left over -10AN from my other crankcase evac setup. Whatever crank pulley you use, it needs to be 5.7" or smaller so it doesn't over spin the vacuum pump. There are a bunch of vacuum pump regulators out there so use what you want.
Or could you get rid of your ATI balancer all together? They also do custom balancers.
Here is the pump mounted below. I had to make spacers but otherwise it was just as easy as mounting it up top.
