LT1 Crankcase Vacuum Pump Kit in Development
Old Apr 24, 2012 | 12:29 PM
  #101
killerz97's Avatar
Originally Posted by SS RRR
If you have the proper ventilation for normal crankcase pressures then you need to do a leakdown.
Whats a leak down test going to show? The motor was just rebuilt last summer and has less than 5k miles on it. Do you think the ring gap is to small?
Old Apr 24, 2012 | 02:03 PM
  #102
96silverram's Avatar
Very nice setup. That has got to be one of the cleanest solutions by far...
Old Apr 24, 2012 | 05:30 PM
  #103
Ralls's Avatar
Originally Posted by James Montigny
I meant to ask you about that; I have mine installed, but have not put the belt on because I was going to put the relief valve in the other VC.
From what I've seen, the kit they sell for the LT1 should never get anywhere near needing that valve.
You probably don't need a regulator valve. I thought about removing mine. I can't get it to pull more than 9in/Hg. I couldn't find any leaks in the crankcase so I think that's all the pump will do (at least on my motor).
What he is saying is, even without a vacuum pump, you should not have oil pressurizing out of all those seals. Assuming you at least have the stock PCV system or breathers off the valve covers, you shouldn't have the pressure your getting. Yes a vac pump could help, but make sure your engine is up to par first. My last motor was machined poorly by a shop and I had all kinds of blow by.
Old Apr 25, 2012 | 11:27 AM
  #104
killerz97's Avatar
Thanks I really hope that is not the case. The car has the stock PCV system still. Would running breathers help? I am also going to double check my PCV system and probably put a new PCV valve in just to see id it makes a difference .
Old Apr 25, 2012 | 12:12 PM
  #105
quik95lt1's Avatar
i dont run a regulator on mine.....i pull 15-18inhg in the crankcase at 6500+rpm.....been doing it for 4 years works awesome and i consume 0 oil even with a 8lb oil ring
Old Apr 25, 2012 | 05:36 PM
  #106
Ralls's Avatar
Here are the updated pictures. You can see the bracket I added on the back of the pump for extra support.
Old Nov 28, 2012 | 03:41 PM
  #107
ramair96ws6's Avatar
From the dead.
I used this setup and it works perfect! I put the pump where the AC was and left the Alt in the stock location. Everything fits like factory.
All of the lines went on without any issue and I used all 12AN parts. I was able to use the stock length belt and tensioner. I will have to take a few pictures tonight and host them up. I wish I would have taken a few before I put it all together. The pump is almost invisible down there...
I didnt change the Balancer as the cost to change it and all of the blower parts really outweighed the cost if this pump fails. I have a $1000 cog drive set up I could give crap if a $300 pump fails Ill just buy another or have it fixed. I spoke to GZ and they said it should hold up find even spinning it to almost 7k rpms. If the Pump fails it is max $150 to rebuild it plush shipping.
Old Dec 4, 2012 | 10:17 AM
  #108
SRZ's Avatar
SRZ
Originally Posted by ramair96ws6
From the dead.
Still have my bracket he made but have yet to order the remaining parts for it. Look forward to seeing some pics!
Old Dec 4, 2012 | 10:23 AM
  #109
nhra686's Avatar
Give us a call. We'll hook you up! www.gzmotorsports.com
Old Dec 4, 2012 | 11:46 AM
  #110
I will take some tonight, xmas shopping has been in full effect lol
Old Dec 7, 2012 | 10:30 PM
  #111
Rob94hawk's Avatar
Hmmm, what are the chances that this vacuum pump setup can help my nagging oil leak in the back of the Moroso pan?
Old Dec 7, 2012 | 11:50 PM
  #112
TwoFast4Lv's Avatar
I said F*** it and cheated. My $350 Vacuum pump setup.
Old Dec 8, 2012 | 08:17 AM
  #113
Shownomercy's Avatar
Man-Crush Warning
Is that even an LT1???
Old Dec 8, 2012 | 11:22 AM
  #114
SS RRR's Avatar
Village Troll
Careful now, my fellow pink screen named friend.
Old Dec 9, 2012 | 06:19 PM
  #115
TwoFast4Lv's Avatar
Sure is! Reverse flow heads 327 block and all!
Old Dec 13, 2012 | 11:56 PM
  #116
Rob94hawk's Avatar
Originally Posted by Ralls
Here are the parts that I used.
-GZ Motorsports Vacuum pump (VP101A)
-Dorman 5.69" vacuum pump pulley from local parts store (300-912)
-Custom vacuum pump bracket
-ASP 5.7" crankshaft balancer (ASP945100)
-ASP smaller alternator pulley
-Custom alternator bracket
-Stock length serpentine belt
-Star Machine -12AN Female vacuum regulator
-Star Machine -10AN fitting w/ baffle for valve cover
-Moroso breather tank (85402)
Was considering doing this until I realized that I have a 7.5" Fluidampr balancer. Is there a larger vacuum pump pulley bigger than 5.69"?
Old Dec 14, 2012 | 01:17 PM
  #117
TwoFast4Lv's Avatar
Call Peterson's
Old Dec 14, 2012 | 03:06 PM
  #118
Rob94hawk's Avatar
Originally Posted by TwoFast4Lv
Call Peterson's
Got a link Ellis?
Old Dec 14, 2012 | 08:43 PM
  #119
TwoFast4Lv's Avatar
http://petersonfluidsys.com/
Old Dec 14, 2012 | 09:59 PM
  #120
Ralls's Avatar
A larger vacuum pump pulley will not physically fit with this configuration. Ask ramair96ws6 what size his crank pulley is. He kept his larger and GZ says it will be ok. However, they do make underdrive pulleys that go between your existing hub and dampener.
