hmm... block ??
Old Feb 24, 2011 | 09:58 PM
nitrous2fast's Avatar
Default hmm... block ??
What's the difference between any sbc genII block and the LT1 block?
Old Feb 24, 2011 | 10:01 PM
rich5368's Avatar
LT1 is a gen II block isn't it?
Old Feb 24, 2011 | 10:02 PM
gregrob's Avatar
They are identical since an LT "IS" a "gen II sbc"....
96capricemgr's Avatar
Can I guess you are MISTAKING the gen 1 1-piece rear main for a gen 2?
The LT1, LT4 and L99(4.3l V8 based engine only in Caprice sedan 94-96) are the gen 2 motors
Old Feb 24, 2011 | 10:08 PM
Vortec anyone... is a gen II non lt based. I just wanted to know if the LT blocks had to be machined differently because of the reverse flow. anyway the reason I ask is I am going to go pick up a gen II 1pc rear-main block and was interested if it would work in the TA.
Old Feb 24, 2011 | 10:11 PM
RamAir95TA's Avatar
No, it will not work.
Old Feb 24, 2011 | 10:12 PM
Whats different.
Old Feb 24, 2011 | 10:16 PM
fergymoto's Avatar
The Vortec is the same as a SBC. The timing cover, water pump, and coolant passages are different. The Vortec is not a Gen II
Old Feb 24, 2011 | 10:18 PM
Oh! I learn something everyday.
Old Feb 24, 2011 | 10:31 PM
WS Sick's Avatar
Basicly it is identical to a 1 peice rear main seal trad SBC minus the front and the head deck surface, all the bottom end measurements are the same.
