Installed A/C delete pulley, pulley has slight wobble...is this "normal"
1 Post
Just going to run heat in the Camaro after all, so I picked up an ebay a/c delete pulley, installed it. I didnt use their bolts and instead used the factory ones and bolted it up. *looks* like it lines up fine, but started the engine and the pulley has a little play in it. Is this how they are supposed to be or did I get a bad one?
I turned the engine off and there is a little play where i could move the pulley a little, nothing major though. Just concerned for driving at higher rpms.
1 Post
Ok, I drove the Camaro to work yesterday (50 mile round trip) with no issues. A little squeek here and there but the belt is still on. I guess if I would have any issues, it would have happened right away on this.
1 Post
Its so/so, not impressed with the wobble or the occasional squeel but for the price, I cant bitch too much. It will do until I fork over the cash for a GM one.
