Lt1 Car ls1 driveshaft Does not fit!!!
Old 03-09-2011, 12:28 PM
Jcl_96TA's Avatar
Default Lt1 Car ls1 driveshaft Does not fit!!!
I got a good deal on a 97 Trans am so i bought it. It was not running so i had to tow it home from delaware. I asked the dude i bought it from to disconnect the d/s and tie it to the torque arm so i could put it on a dolly when i got there. None the less i get home with it to discover the drive shaft is gone. I was pretty scared at that point because i was towing it at about 90mph for a good ways down the turn pike and a twenty pound drive shaft cartwheeling through someones windshield at 90mph could be ugly. But anyhow bought a ls1 drive-shaft from a member on here and it wont fit my rear. WTF!! Pissing me off cause everyone said they were a direct swap. Not the case at all the u joint on the ls1 shaft is way to big to fit into the 97 yolk on my stock rear. So i bought a 97 u joint hopeing i could peice the two together and make it work, but no dice. I found this thread, but it kind of trailed off with no real answer as to how i can make it work.
https://ls1tech.com/forums/lt1-lt4-m...-question.html
Anyone got a clue what i can buy cheep that will make it work on my 97Ta???
Old 03-09-2011, 12:33 PM
gjohnsonws6's Avatar
maybe someone put an adapter joint in it,1310 to 1350?take the shaft to your local driveline shop for info of the u joint size in the new shaft you are trying to use,what is the tube size on it?Might be an aftermarket shaft?
Old 03-09-2011, 12:42 PM
Jcl_96TA's Avatar
Hmmn i talked to the guy who i bought it from and he said he has a 12 bolt in his car, so should i get a stock ls1 U joint? The stock lt1 wont work and the one thats on it wont work..
Old 03-09-2011, 12:43 PM
ElkySS's Avatar
thats what it sounds like to me.
Old 03-09-2011, 12:48 PM
Wicked94Z's Avatar
yea the stock u-joint is a Saginaw 3R, you have a 1350 on there i'm sure
Old 03-09-2011, 04:24 PM
James Montigny's Avatar
I agree, the 12bolt uses a larger Ujoint (1350), that's why it doesn't fit.
Just get a new Ujoint that adapts from 3R to 1350 and you'll be fine.
I'm sure that you'll find the PN if you search for "12 bolt U joint", I went though that a few years ago.
I've installed quite a few Fbody driveshafts over the years, everything from 83 to 02 is interchangeable until you change the rear end.
(82s with 200R4 do not fit)
Old 03-09-2011, 04:57 PM
WS Sick's Avatar
So why did the stock 97 u-joint not fit in the driveshaft?
Old 03-09-2011, 05:00 PM
It should have, unless the driveshaft you have is not stock and has a 1350.
That's not necessarily a bad thing, especially if you have a 12-bolt.
Quick Reply: Lt1 Car ls1 driveshaft Does not fit!!!
