EFI Users...question for ya.
Old Mar 18, 2011 | 02:46 PM
SRZ's Avatar
SRZ
Question EFI Users...question for ya.
EFI 24x owners.......
Do any of you know whether stock LS spark plug wires will be long enough to use? I'm almost sure everyone is using 90* boot ends too, right? Not trying to buy all the necessary tools to make a custom set just need them to be long enough to begin w/. I'll be using Taylor 10.4mm as that's all I ever use to begin w/.
Thanks!
Old Mar 18, 2011 | 04:41 PM
97LT1's Avatar
Thanks!
I mounted my coils under the cowl area, and also cut my own with 90 boots. (some I left straight boots on) I forget the place, but there is one that will create a set for you if you give the measurements. I had good luck with taylors, but there have been a lot who have not.
Old Mar 18, 2011 | 09:35 PM
SRZ's Avatar
SRZ
Hey, thanks. Had a brain fart and figure maybe just maybe, it's possible to use my existing 10.4 and cut them to size. Not sure how much the tool and the ends would be but I am hoping they're cheaper than buying a new set.
Old Mar 19, 2011 | 06:45 AM
Blackbirdws6's Avatar
What valve covers do you have? Anything much taller than stockers and you will have to cut your own.
Old Mar 19, 2011 | 09:55 AM
SRZ's Avatar
SRZ
Brian,
I've got some ProForm's, and they appear to be stock height or maybe a tad taller. Did you have to use those spacers in between the bracket and vc's on yours? I know you've got those taller vc's.
Old Mar 19, 2011 | 10:41 AM
camar0corey's Avatar
So you have factory length LT1 wires now? Then yes they will be plenty long for you to use. Factory LS1 wires are a tight fit out of the box and will touch the headers, not enough length to modify for 90 degree boots.
Old Mar 19, 2011 | 10:42 AM
BizZzatch350's Avatar
Moderator
Sillas,
I used a set from Katech made by MSD, they are meant for LS1s relocatin wires to the top of the fuel rails, they are enough length to work with my Hooker long tubes. Only down side is, they aren't 90* boots on the plug end, which still works, but I find a pain in the ***.
Old Mar 19, 2011 | 04:25 PM
SRZ's Avatar
SRZ
Is there a kit out there that I can buy to build my own then? I see universal kits but they're for the traditional style distributor etc. Got to be something out there as I don't want to chance buying a pre-made set and then being too short. Thanks guys..
Old Mar 20, 2011 | 12:53 AM
Yea I used the spacers for the bracket just to keep everything directly off the cover. To make your own wires, you need the 90 deg boots, good amount of wire, and the boots for the coils. I'm using opti boots and they seem to work fine.
Old Mar 20, 2011 | 10:45 AM
SRZ's Avatar
SRZ
Trying my hardest to find 10.4 boots for the coils but they don't seem to be sold seperate, that'll suck as then I'll have to ditch my existing wires from the opti and go 8.5's.
Old Mar 20, 2011 | 09:50 PM
James Montigny's Avatar
They were way too short for my Canton VCs, I had a custom set fabbed up.
I have 10 brand new MSD LS2 coil boots left over if you want to alter your Lt1 wires or make a custom set.
https://ls1tech.com/forums/parts-cla...ts-45-new.html
Old Mar 21, 2011 | 09:10 AM
airfix's Avatar
You could get that blancoss guy to custom make you some, I know he does lots of LS1 and LT1 plug wires.
Old Mar 21, 2011 | 09:11 AM
Does he still make those? I couldn't get a hold of him. I assumed he was gone.
Old Mar 21, 2011 | 09:40 AM
airfix's Avatar
I'm not sure, I got my wires from him roughly 2 years ago. I assumed he still made them maybe not... I believe he was a sponser on here dunno if he still is. He also sold the wires on ebay too, that might be a way to get a hold of him.
Old Mar 21, 2011 | 09:46 AM
SRZ's Avatar
SRZ
Never heard of the name/guy. I'll just call Taylor and see about getting some universal lenght wires w/ the LS coil boots already installed. Supposedly you can buy them this way from them.
Old Mar 21, 2011 | 09:59 AM
Actually, I bought from him a few years back too. He did great work.
But I haven't seen a post from him since 2009.
That's an option, or just use the LT1 set you already own and add LS boots.
You're going to want LT1 style 90* plug boots to clear headers.
Old Mar 21, 2011 | 12:19 PM
SRZ's Avatar
SRZ
This is what I wanted to do originally but it seemed nobody sold LS boots by themselves. Premade kits only. for LS engines.
Old Mar 21, 2011 | 12:32 PM
Sure they do, they're $8 a pair from Jegs or Summit.
I have 5 pairs sitting on my workbench.
>>>>> https://ls1tech.com/forums/parts-cla...ts-45-new.html <<<<<
Old Mar 21, 2011 | 12:49 PM
duh's Avatar
duh
If you want to make your own just use the cut to length set of lt1's. The coils of the ls engines are the same terminal as the opti. Then all you need is the 90* part for the plug. Built a set of msd's this way for a ltcc converted car and they worked fine.
Old Mar 21, 2011 | 12:57 PM
The terminal inside is the same, but the boot on an LS is bigger.
I guess you could cram an LT1 boot over an LS coil though, it just didn't seem to fit very well when I tried it.
LS1
LT1
