My new Turbo LT1, **Pics Inside** have a few questions.
Your running what 16psi? The 104’s are 2 steps cooler than stock, and I’m only at 8psi. Would it be a good idea to go 3 steps cooler at only 8 psi? The compression ratio is 8.5:1. I do want to turn it up to 10psi, but around here we only have 91 around here and don’t know if it will detonate. I need to get the cable and do some data logging so I know what it’s doing right now.
I do want to relocate the fuel line and all the vacuum lines but not too sure where to stuff them. The engine bay is a MESS!
I might look into getting those locking header bolt, When I was removing the manifold I noticed that a few where rather loose. The rear most bolt was finger tight and that’s what caused the gasket to fail. They are the ARP SS 3/8"-16 bolts.
And these are the header gaskets I'm running. They are by far my favorite over the fel-pro and percey's.
http://www.summitracing.com/parts/EA...BERL/?rtype=10
I read some where that the 104's where 2 ranges cooler, but don't believe everything that you read right?
Those are some damn nice header gaskets! I already ordered the Felpro gaskets, but if they ever go out on me I know what I'm going to be getting next. Thanks for the link!
Everyone likes pictures right? So here are some of me cleaning out my threads and fixing (I hope) a cross threaded hole. Yes I did use lubricant.
The "Thread Restore Kit" from Autozone, $96 to rent. . .
![](http://i35.photobucket.com/albums/d164/A_Deer/mms_picture-2.jpg)
Threading it into a clean hole to clean out any garbage.
![](http://i35.photobucket.com/albums/d164/A_Deer/mms_picture3-1.jpg)
![](http://i35.photobucket.com/albums/d164/A_Deer/mms_picture5-1.jpg)
A little gunk that came out of the hole.
![](http://i35.photobucket.com/albums/d164/A_Deer/mms_picture6-1.jpg)
Here is what i thought was a clean hole. The bolt was a little hard to put in at first. Now it screws in easily.
![](http://i35.photobucket.com/albums/d164/A_Deer/mms_picture2-1.jpg)
It looks MUCH worse in the picture. It was not that bad after I wiped it on a cloth and inspected the particles.
I did not get any picture of the damaged hole that I hopefully fixed. Very little shavings came out and the bolt threaded in with ease after I was done.
As soon as my gaskets get here Wednesday I will start to put it all back together and hopefully everything will go smoothly. This time I will be the one doing all the work! No help please and thank you.
