Rocker arm fracture? Pics inside
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
Working on installing my EFI connection coil/bracket and noticed through the oil fill hole a slight crack or flash on the rocker arm. Pulled the cover off and found two w/ this. SO, how serious is this? It appears all the way through but then again unsure. The 1st rocker in the pic is loose so I wiggled it to see if it was totally compromised and doesn't appear to be but still. Anyone seen this before?
I want some Comp mags. What ya got Greg?
Yea I wouldn't start the engine before that's fixed. I assume you have some significant seat pressure with the engine being setup for boost and might have led to the fracture you see. I would hope the ultra mags won't have any issues....mainly because I have them on my new build lol. Good thing you caught it before it became a big problem.
i think he meant call comp and have them replace the bad ones, then turn around and just sell them on ebay. I dont think he meant to sell them as is and list them as fine. I could be wrong though. Im not into screwing people like that.
