Spark plug wire question, or two!
Cal
I would go MSD and get the LT1 opti booted wires and cut hem to length and put the spark plug ends and boots on. I have never had an issue with the MSD 8.5mm super conductor wires period and be done with it. Chasing electrical gremlins in cheap wires just aint worth it.
Find something else to skimp on.
most of the Jeg's and Summit brand stuff is made by the top manufacturers
but sold as generic so they have a hand in the generic market..
2 things..
first..make sure you have a good premium crimp tool..borrow one if you have to..
second..you have to be real careful when routing the passenger side wires up
by the waterpump for the over the valvecover set-up..
you have to make a holdback bracket to keep the plugs wires clear of the serp belt..
2 things..
bracket I made to..but it was 2 of the bolts underneath one
was a bolt that mounts the large aluminum bracket to the block ..(holds the power steering pump and a/c compressor..)
I think the other was the bottom bolt of the water pump..
I used a piece of an old aluminum gutter..trimmed it into shape,was about 1" wide about 4 or 5 inches long with an offset in it..
I drilled 2 holes..one at each end to match the bolt locations and painted it..
looked like it came that way from the factory..LOL
that's all anybody had 10 years ago..
