few quick questions engine harness clean up
Old Apr 2, 2011 | 06:45 PM
litch2004's Avatar
Sounds good thank you.
Old Apr 3, 2011 | 01:48 PM
jasonisdn's Avatar
i never got to the abs wires or the cruise control wires yesterday. got started and had to leave to fix a friends network at home.
Old Apr 3, 2011 | 01:54 PM
litch2004's Avatar
It's okay, not in a huge rush. So when you figure it out just let me know.
Old Apr 6, 2011 | 11:46 AM
litch2004's Avatar
Jason any updates yet?
Old Apr 6, 2011 | 02:06 PM
jasonisdn's Avatar
sorry man not on the wiring. had to finish the iac deal so we can get my motor back before my tranny is done. i might get something done on it this weekend.
Old Apr 6, 2011 | 04:03 PM
litch2004's Avatar
What exactly were you doing to the iac? I saw your thread but wasn't to clear on what you were trying to accomplish.
Old Apr 6, 2011 | 06:11 PM
jasonisdn's Avatar
i have a monoblade TB which does not have a passage on the back side of the TB to seal to the factory IAC passage in the intake. our lt1's need to pull from the IAC thru the passage so it can idle correctly. the air distribution in the lt1 intake sucks at idle without it. it fouls the back four plugs. i got tired of playing with the idle tables in LT1edit and checking plugs. so i spoke to another member, who is doing it a different way, and i came up with this pattern. this way it uses filtered air that is already accounted for by the maf, so it shouldn't throw off the ve tables.
scroll down to the 7th post and look at that picture (the ones on my laptop are to big to upload).
https://ls1tech.com/forums/lt1-lt4-m...-58mm-bbk.html
Old Apr 7, 2011 | 12:15 PM
litch2004's Avatar
O ok. I for ya. That could be why my idle is ****.
Old Apr 13, 2011 | 12:54 AM
litch2004's Avatar
Moved to OP
Old Apr 13, 2011 | 02:43 PM
litch2004's Avatar
Bump for the day
Old Apr 14, 2011 | 05:17 PM
litch2004's Avatar
Bumpp
