few quick questions engine harness clean up
I am wanting to unpin all the things that have been deleted. All a/c components, egr, air pump, abs, cruise control, maybe more but can't remember. Is their any ill effects as in other circuits tied in? Any help will be greatly appreciated.
Hey James in the 93 harness what us c100. I don't remember disconnecting in. I'm want to remove it as well if I don't use it anymore.
Edit: I remember now that it plugs into the harness that runs up the passenger side and up.to the core support. Now my questions is that one of the wires i cut to remove another unused pigtail tied into this plug. It is a brown wire in which I know is a ground. So can I just run it to the block ground that is right there by it, or even a chassis ground and call it good?
I pulled my 93 harness out a few weeks ago.
Mine have been as well for a few years now. I'd like remove all of it as well as relocate the fuse box, headlight module, and ecm. I already know where I'm putting the ecm but I'm not looking toward to extending all the wire for the fuse block. The is a lot of those in there.
