Having issues! Need your guys' help ASAP.
I pulled the fuel rail yesterday and today im gonna borrow a set of stock injectors that my uncle has just see if maybe I have a bad one.
Im trying to rule out the bottom end as much as possible cause the way it sounds, it just feels like maybe 1 cylinder has a slight missfire or is leaning out but makes the sound of a header leak and that cant be what it is and I can't pinpoint it at all.
All I know is there is a tick coming from the drivers side of the motor towards the back (maybe 5 or 7 cylinder) and it makes a spitting/missing sound when I rev it up above 1500 RPM.
I will try to post a vid once I put the fuel rail back on.
Alright I've tried everything under the sun that I could think of to troubleshoot this "Ticking" noise and yesterday when I went to start it, I noticed my oil pressure gauge was not even registering a PSI!!
SOOO...I think I came to the conclusion that either my oil pump took a **** or the oil pump drive went bad. which would maybe explain why my oil pressure gauge would slightly fluctuate back and forth for the last year ive been driving it.
Has anyone had a similar situation like this? Do you suppose this was the culprit?
Might just be time to pull it and do my Nitrous 355 like I planned.
