manual fan switch
on one tab i connect the blue wire of the fan which i think is the high speed, and then on the other tab i connect the green wire that is low speed. Then the last tab i just ground it where ever their is bare metal?
Don't know if you are OBD-I or II. There is no car info provided.
http://shbox.com/1/fan_sw_diagram1.jpg
http://shbox.com/1/fan_sw_diagram2.jpg
DPDT = Double Pole Double Throw Has six terminals, like two of the above with one lever.
Single pole connects the center to one end or the other depending on the position of the lever.
http://www.1728.com/project2.htm If you want to wade through it.
Al
