Ls7 lifter preload
Old Apr 29, 2011 | 11:06 PM
robss96dcm's Avatar
Question Ls7 lifter preload
I seem to be a little confused here, most people using the ls7 lifters in lsx applications are shooting for about .080 preload. When installed in lt1 applications there going about a 1/4 turn past zero which is about .010 preload if my math is correct.
Why so little in the lt1's
Old Apr 29, 2011 | 11:08 PM
wrd1972's Avatar
I play it safe and go 3/4 PZL, but thats just me. If I were racing, I would do 1/4 turn PZL.
Old Apr 29, 2011 | 11:17 PM
jaycenk's Avatar
I did a tad over 1/2. about 2/3rds
Old Apr 29, 2011 | 11:28 PM
gregrob's Avatar
Full turn is factory spec, and LS7 lifters are factory replacement. Soooo....
Old Apr 30, 2011 | 05:03 PM
SoxXpupPeT's Avatar
I had tryed that in my car. As im slowly doing them with the engine running it started to run like crap!
I have mine set at 1/4 turn. I might fool around and see how they respond at 1/2 turn
Old Apr 30, 2011 | 05:31 PM
z28_theantirice's Avatar
When I initially did my motor I did either 1/2 of 3/4 cant remember, ended up going with 1/4 and the motor felt a lot smoother with the 1/4 turn.
Old Apr 30, 2011 | 06:16 PM
gregrob's Avatar
Maybe they require less. It would be interesting to know what GM calls for on the LS7.
Are you guys using 1/4 turn sure your pushrod length is correct?
Old Apr 30, 2011 | 06:17 PM
litch2004's Avatar
Mine was loud as Hell at 1/2 so I went with 1/4 and ran great. Not sure about why it is just is lol.
Old Apr 30, 2011 | 06:18 PM
litch2004's Avatar
rrob, mine were measured three times by three different people and used a micrometer to measure test rod.
Old Apr 30, 2011 | 06:23 PM
SoxXpupPeT's Avatar
same here. but do remember. not all LS7 lifters are the same. There have been alot of reports with people having bad batches iirc
Old Apr 30, 2011 | 06:27 PM
litch2004's Avatar
I remember. Mine are about a 2 years old. I have only put 200 miles on them. It was my rockers that were loud. Went back redid all of them and marked a line on the oily lock to determine movement. All is good.
Old May 1, 2011 | 08:34 PM
robss96dcm's Avatar
My understanding is .060 on stock ls7 engines, in a lt1 that would be about 1.5 turns past zero lash!
Old May 1, 2011 | 08:54 PM
speed_demon24's Avatar
It would be about half that.
Old May 2, 2011 | 05:12 AM
RamAir95TA's Avatar
I've always done 1/4 TPZL.
Old May 2, 2011 | 08:00 AM
jasonz28camaro's Avatar
Yep, they call for 1/4
Old May 2, 2011 | 08:08 AM
wrd1972's Avatar
Based off of what reference?
Old May 2, 2011 | 09:44 AM
the_merv's Avatar
LS7 Lifter perload is .080 ideal, can range from .060-.100, always go with the larger one past .080 when selecting proper pushrod size.
There is a difference in the LS7 Lifter vs. the others..different Pushrod lengths get specified if you use them , I beleive the number most are using is .025", but it would be best to measure.
Old May 2, 2011 | 11:10 AM
Big Al's Avatar
Your math is correct, except you are moving the center point, not just one end. Think about it.
Al 95 Z28
Old May 2, 2011 | 03:14 PM
robss96dcm's Avatar
Are you saying it should be .030 = .75 of a turn? And Why?
Old May 2, 2011 | 03:21 PM
robss96dcm's Avatar
Al 95 Z28
Not sure if i understand you correctly, are you referring to the change in valvetrain geometry?
