PTV clearance for a friend
His build:
stock crank
eagle forged 5.7 rods
speedpro pistons +6.1cc valve reliefs(Look just like stock) 4.030
victor reiniz .026 (impala) headgaskets 4.110 bore
55cc heads 2.00/1.56 valves
cc306 cam
1.6 rockers
new stock gm timing set
crane 10308-1 valve spring kit
pistons are .005 in the hole
Im just curious on the valve clerance.. I know the compression will be about 11.9:1..
lmk what you think and i will relay the info
6" rod, tight piston to wall and 4032 pistons?
I was barely touching on my last motor with .032, 6" rod and 2618 JEs and somewhat loose piston to wall. I think .031 is tight but good for your average 355, but i have doubts about joe blow average hillbilly ls1tech'r doing a 383 that tight.
wicked So He should be more concerned about the piston hitting? I verified they are indeed .005 in the hole.. Anything else that i should check?
My piston to valve the other day was 0.00000000000000000000" I like to run em real close too apparently
