Would a burnt plug wire boot cause the engine to hold back?
Old 05-05-2011, 09:53 PM
l 95 Trans Am l's Avatar
Default Would a burnt plug wire boot cause the engine to hold back?
I burnt my #7 wire boot on the header, day before i discovered it the engine would hold back around 2k. Would that cause it to hold back like that or would it just make it run sloppy?
Old 05-05-2011, 10:09 PM
NewOrleansLT1's Avatar
both...
Old 05-05-2011, 10:22 PM
Originally Posted by NewOrleansLT1
both...
Well the reason im asking such a dumb question is because when i seen the burnt wire i disconnected it, started the car, and it didnt hold back, just ran sloppy.
Old 05-05-2011, 10:31 PM
because when you unplugged it you just had a dead cylinder, but when it is plugged you have a cylinder with intermittent spark which holds your engine back.
Old 05-05-2011, 10:46 PM
Oh ok, thanks for the help. Just curious if I should be replacing more then just wires
Old 05-06-2011, 01:20 AM
95_TA_USMC's Avatar
i had a #8 plug wired burned through on the header, and it would do both... low rpm struggle and hold back, crazy intermittent idle, and rich smellin like a ****! but 3500 and up was screamin good drivin...
Old 05-06-2011, 09:27 PM
Well mine seems to run ok, except the one day it started struggling at low RPM. Then I had noticed the boot was directly on the header, burnt almost to the wire, then i moved it and put heat resistant tape on it just to get it home. It ran ok but still felt like it had no ***** at idle
Old 05-06-2011, 09:52 PM
nitrous2fast's Avatar
I had a burnt wire before and if i blipped the throttle the Rpms would only go up to 2000 rpms but if I slowly rolled into it, it would go to red line.
To resolve this issue, I ordered a OTVC kit from CC Performance with MSD Superconductor wires. I also ordered 8 heat resistant spark plug boot protectors off Jegs, they are about 6 inches long each. THESE WIRES ARE NOT GETTING BURNT lol
Old 05-07-2011, 07:59 AM
BIG_T's Avatar
nice choice on the ovtc kit. cc makes some quality wire sets
Old 05-07-2011, 06:51 PM
Yeah I heard good things about them so I went with their kit. Hope it works well
Quick Reply: Would a burnt plug wire boot cause the engine to hold back?
