LT1 Oil Priming Question
if you dont know what to look for when looking for oil in the galley there should be a flow of oil coming form the back of the motor to the front. check out my post below from a few days back, i had problems priming my motor.
https://ls1tech.com/forums/lt1-lt4-m...umping-up.html
I always prime the **** out of my engines with an old distributor shaft and a drill, but sometimes it takes a while to get oil all the way up top.
Also you can take oil pressure from just above the oil filter boss or from the back intake manifold rail.
Last night when we were trying to prime the motor, two different times, we turned the crank over 1 revolution. We also tried to spin the push rods to ensure they were seated properly. This may may be a case of not giving it enough priming time. We called it quits after 30 minutes. Just seemed odd that the left bank built up after just a few minutes & the right side didn't build up at all. We did use a 110v power drill & a priming tool. This site gave us a lot of good tips to get going.
http://www.jegs.com/i/Proform/778/66896/10002/-1
I have a 96 vette that has that distributor hole capped off at the block. (Which implies I have the intake manifold off) If I take off the capping assembly it has a helical gear that comes out with it and exposes the oil pump shaft. Not sure what the helical gear does but cranking with drill only gets me a lot of oil gushing up through the hole the gear came out of.
I'm using a OEM 27060 priming tool from Advanced Auto. It has a collar but obviously isn't the right tool for this application since it does nothing to build pressure.
Can anyone tell me how to prime an LT1 that doesn't have a conventional distributor? It's got one of those blasted OptiSparks on front of engine.
If you are re-using the stock oil pump drive shaft I would buy a ARP or Miloden solid one. The plastic collar on the stock one gets old and brittle and can crack on re-install
Many people just pull the fuel injector fuse and coil wire when motor is in car and just crank with starter until oil pressure shows
also on the oil pump drive gear top of motor...be very careful on tightening that small hold down bolt or you will crack the plastic top on the gear drive....
