Lifters not pumping up
i took off the manifold and rented a priming bit form Autozone. I started t to prime for 5 min and nothing still with 60lbs of oil pressure. I took out each lifter individually and saw oil traveling threw the lifter galley at a good velocity, almost enough to reach the other side, is that good enough??? i can see the lifter very slowly allowing oil to pool on the area where the puchrod would sit and thats about all. my drill is a Dewalt 18v.
I was told maybe the freeze plugs fell out in the front of the motor but i pulled the timing cover back enough to see them sill in place, they said if they were out my oil pressure would be low too and it is not.
The lifters are LS7 and they came right out of my old block straight into my new motor. they are all still soft and not allowing my valves to open all the way. should i get new lifters and try to prime again??
with the intake off i turned the key to the on position, started priming and viewed the dash gauge rise to 60lbs and fall when the priming tool was engaged. i do not feel that a mechanical gauge would do any dif.
This is a dumb question, but I have to ask, are you using the dogbones and spider tray to ensure the lifters are riding in the bores correctly?
http://s151.photobucket.com/albums/s...t=IMG_1204.mp4
Before ditching the LS7 lifters I'd get a right angle drill and try that out. I'm not sure how many RPM that cordless of yours produces, but I'd go for something that can produce over 1000rpm and see what happens.
now im going to get a better drill and try to get oil to flow. i got one of the ls7 lifters to push oil through a pushrod.
there is a small plate just below the the cup on the lifter where the pushrod sits. there is flow out of each lifter at this point but not enough. i place a pushrod on top of the lifter and can sometimes get oil to the top of it, no rockers are hooked up at this point.
if i stick something small enough in the top of the lifter that will push down on the small plate i get a lot of oil coming out of the top of the lifter. how does that plate work and if i hook up all the rockers will it start to move so the oil can come out of the hole? with the pushrod engaged it doesnt allow the plate to move at all so it is the same. with it running would that be a different story?
Al 95 Z28
Al 95 Z28
