cam tuning help
Old May 9, 2011 | 11:04 AM
nater36's Avatar
Default cam tuning help
just installed my comp cams 280xfi, and WOW did it make a difference... however in the low rpms the tune is off, i acheived a great idle with 30 degrees advance... the car just slightly hesitates in throttle response below 2k, and wont cruise in 6th under 1500 (55mph) w/o slight surge unless the car kicks out of closed loop which it does? and car runs great (rich at 13.8-14.2)
any ideas/suggestions?
96lt1 m6
Old May 9, 2011 | 11:17 AM
moehorsepower's Avatar
Originally Posted by nater36
jcar runs great (rich at 13.8-14.2)
96lt1 m6
Thats lean, not rich..
Old May 9, 2011 | 11:43 AM
nater36's Avatar
thats not wot... thats cruise afr
wot is 12.1
Old May 9, 2011 | 12:58 PM
mguidry629's Avatar
That's a little rich for cruising, but not rich enough to create any problems. You want 14.7-15.0 for optimum fuel mileage. Need to adjust MAF tables to take out a little fuel. Are you getting your AFR from a wideband?
Why would it "kick out" of closed loop? It should stay in closed loop until you kill the motor.
Old May 9, 2011 | 01:05 PM
nater36's Avatar
thats my point, it runs better with the richer a/f.. yes using wideband. when its in closed loop it surges and for some reason it kicks out of closed loop after ten minutes or so and runs great
the surging is just barely noticeable through the gear shift as it lightly stumbles
Old May 9, 2011 | 02:10 PM
gregrob's Avatar
You need to lean that area out.
Old May 9, 2011 | 02:49 PM
nitrous2fast's Avatar
it probably needs a little more timing too..
Old May 9, 2011 | 02:57 PM
LSWHO's Avatar
I found that more timing helped out the most. And 30 degrees sounds low for idle. My car likes more. It took my map from 62ish to 57ish.
Old May 9, 2011 | 04:38 PM
about 38* of timing at idle is what many LT1's like; stock and aftmkt cam.
Old May 9, 2011 | 11:25 PM
nater36's Avatar
.. i think you guys are missing the point... it idles great, it drives great when in open loop and rich... when in closed loop and swinging around 14.7 it doesnt drive AS well... with light throttle it commands 40 degrees, is that too much?
Old May 10, 2011 | 01:28 AM
Wicked94Z's Avatar
I've tuned about 4 different LARGE cams now and have yet to see ANY improvement in the idle quality (vacuum) running more than about 32º timing. The last was on my car with the HSR and a 262/265 109.75lsa cam. The longer runners want more timing and generally don't idle as well with big cams... Well it runs the best at 32º of ACTUAL timing verified by timing light, not just some arbitrary number you plug in the computer at the mercy of the cam grinder's accuracy and timing chain slop. It makes about 4.5" of vacuum there, and did about 4" with only 28º.
Now, if you want to eliminate surge you need to LEAN the car out, I've run 1.05 lambda with good success at cruise and had ZERO surge problems with a 240/252 107lsa cam and a 6 speed with only a 4.11 gear and 28" tires. I never see a benefit running more than about 38º of timing at cruise, the motor just doesn't need it with the compression I run and fancy AFR chambers.
Old May 10, 2011 | 01:32 AM
gregrob's Avatar
I have found 32-34 to work best with what I've tuned. I agree, no reason to go higher and you may actually make it transition less smoothly off idle.
Old May 10, 2011 | 02:23 AM
LSWHO's Avatar
I am at 37 degrees and I adjusted the closed tps and open tables to match so there's no transition problems. I added until I stopped seeing the map value drop.
I also found adding timing and smoothing out the tables at cruise smoothed it out the most. I leaned it out a bit and it's almost completely gone.
Old May 10, 2011 | 08:17 AM
quik95lt1's Avatar
yep i idle mine at 33 i got mine running 14.5 to 15.0 cruising around..........the surge will never go away but its better.....long as i keep it over 2500 or so its happy
Old May 10, 2011 | 09:48 AM
nater36's Avatar
ill give the leaning out a shot... should i set max advance to 38?
