Update..got the stroked/turbo and nitrous 97 ss tuned ...
Yea i got it tuned today but it was hell tuning it...we messed up one pcm ..had to go run 25 miles away to grab one...the master cylinder f'd up on me ..didnt know the master on our cars didnt work that good without abs unit...had to grab a prop valve .... And the sensor on the elbow kept popping out but the tuner had a after market one that screwed in so im removing the factory brake booster and master for the strange master.....but all and all it made good power with a ok tune cause the injectors maxed out...871rwhp 826tq 23lb boost 50shot of nitrous ....with post dyno sheet when i get to a scanner
Awesome HP numbers even maxing out the injectors. what fuel pressure where u guys running? Did youll try bumping the pressure upto 55-65psi? What fuel,turbo and compression are u guys running?
