LT1 Oil Pump
Old Jun 8, 2011 | 10:17 PM
MichaelWade's Avatar
Default LT1 Oil Pump
So I got an Meilling LT1 replacement pump and it came with a white plastic collar that I'm assuming goes on the shaft coming out of the oil pump. When I put it on It hits the pump housing and doesn't allow the pump to set all the way on the main cap. Am I doing this right? Does that sleeve have to be there?
Old Jun 8, 2011 | 10:31 PM
food nd cars's Avatar
I would suggest replacing that nylon collar with a steel collar. I got one from my local machine shop for about 15 bucks.
Old Jun 8, 2011 | 10:35 PM
What's the collar for?
Old Jun 8, 2011 | 10:37 PM
Melling IS-55E
That is an example of what I am talking about and that should work directly with you oil pump. The Nylon coupling has been used with SBC 350s for a long time and are not prone to breaking.. BUT wouldn't you rather have a metal piece instead?
Old Jun 8, 2011 | 10:38 PM
Its supposed to keep the shaft and the pump connected. I def wouldn't run your engine without it.
Old Jun 8, 2011 | 10:55 PM
Thanks for the info, I'll def be getting a metal one made.
Old Jun 8, 2011 | 11:15 PM
karllubich's Avatar
X2 on that one
Old Jun 9, 2011 | 06:55 PM
great421's Avatar
If you get a replacement steel shaft, it comes with a metal collar attached - $10
