lt1 ready for boost?
Old Jun 12, 2011 | 01:24 PM
93stroker's Avatar
Default lt1 ready for boost?
got a 383 stroker lt1. eagle rotating assembly with forger crank, rods, and pistons. rods are h beams and mahle iverted dome -16.00 cc. port and polished heads. now for the question, what kind of psi would this setup hold? any one buid something close to this? i will be running a gt-45 with a air to water intercooler.
Old Jun 12, 2011 | 01:31 PM
pro94lt's Avatar
Do you know your cr? in the end it's all in the tune. I would say a stock motor with the best tune might be better than a all forged motor that's lean and has to much timing. Whatever you do you'll enjoy it it's a whole nother game...
Old Jun 12, 2011 | 01:35 PM
vetteboy99's Avatar
Aren't LT1's nitrous ready from the factory? Some random guy told me that, but he said it in a way that told me "This guy's know's a **** load about these cars"
Old Jun 12, 2011 | 01:46 PM
02v8ta's Avatar
Both the lt1 & ls1 will take a 100shot stock no problem.
Old Jun 12, 2011 | 01:50 PM
LSWHO's Avatar
Nitrous isn't boost.
Old Jun 12, 2011 | 01:54 PM
vetteboy99's Avatar
We, at least I, know that, but the topic got me thinking about nitrous for a second.
Old Jun 12, 2011 | 02:03 PM
02v8ta's Avatar
lol @ myself. Dumb stuff comes out your mouth when you don't read everything carefully and go off of someone elses post.
Old Jun 12, 2011 | 03:51 PM
93stroker's Avatar
thank you lswho. i thought about spray but im not a huge fan of it. im looking to make abround 600hp at the wheels. i think about 13-15 lbs would do it
Old Jun 13, 2011 | 02:10 PM
qc97z's Avatar
Has the block been decked? How much? What CC are the combustion chambers in the heads?
What are the flow numbers of the heads? What are the intake port sizes? What are the cam specs?
These are all things that we need to know to provide a more accurate guess.
I make 648 RWHP @ 6500 RPM (15 psi) on a Procharger F1.
Theoretically, a motor built a lot like mine would be able to make 600+ at 13-15 psi.
Need more numbers.
Old Jun 13, 2011 | 03:51 PM
93stroker's Avatar
im not sure of the cc on the heads. all i know is they are port and polished. they were on it when i got the car. cam is a comp .503 intake .510 exhaust. i think im gonna need a custom grind cam for the turbo. heads have never been on a flow bench.
Old Jun 13, 2011 | 04:46 PM
David94TA's Avatar
My last build was a 383 with 16 cc dish pistons, but with 53.6 cc combustion chambers, my CR was still around 10.6-10.7:1 so I only ran about 6 lbs of boost. I ran a water/methanol injection system with no intercooler and had it tuned and it did pretty well, all things considered. With a 224/236 573/571 116 lsa cam and just mildly cleaned up heads, it made 467 rwhp/ 470 rwtq.
Old Jun 13, 2011 | 05:10 PM
mguidry629's Avatar
Not to hijack, but I have a question or 2: isn't a dish the same as inverted dome? Why call it -16cc if it's really adding 16cc? At +16cc, your still above 10:1 cr assuming 54cc chambers.
Old Jun 13, 2011 | 08:54 PM
projektnitemare13's Avatar
yeah my motor is being built with 31cc dishes and 61cc chambers to get to 8.8:1 but I plan on running 18-20psi. yours sounds like it will most likely be a wee high for serious boost, but you can still probably get away with a low boost set up
Old Jun 14, 2011 | 09:51 AM
93stroker's Avatar
i think im gonna keep the boost pretty low anyways
Old Jun 14, 2011 | 10:12 AM
SS RRR's Avatar
Village Troll
As long as the tune is done correctly used discipline. LT1 owners by the **** ton have put spray on their car, got greedy and have blown ring lands out the exhaust only to land upon the windshield of some unsuspecting vehicle sending it careening off the road in a fiery ball-o-death.
Old Jun 14, 2011 | 12:21 PM
qc97z's Avatar
^ Awesome visual. Be careful about what you describe....some people may do that on purpose now!
Old Jun 14, 2011 | 12:31 PM
Z28Roxy's Avatar
383 with -20cc pistons and 62cc heads = 9.3ish to 1
Old Jun 16, 2011 | 10:23 AM
93stroker's Avatar
im gonna have to find the chamber size of the stock heads and see if i can come up with a cr
Old Jun 16, 2011 | 10:33 AM
54.4 or 54.9 i think, 54.4 were LT4s and 54.9 were stock LT1
Old Jun 16, 2011 | 12:09 PM
Z28Roxy's Avatar
I ran into this problem with my stock heads when I went to build my motor, that's the main reason I went with the trickflows (though now I wish I had gone with AFRs). Pretty much the only way to get compression down low enough with the stock heads is to run a -31cc piston. Heads might be in your future unless you want to run low boost.... though you could try a custom cometic head gasket to help get your compression down more..... though you're still stuck pulling the heads if you go that route.
