Which valvesprings do i need?
Old Jun 27, 2011 | 01:20 PM
lt1camaro383's Avatar
Default Which valvesprings do i need?
Ai 226 / 234 - .569/.570 - 110 LSA
I would just like some input about what type of spring some of you guys used.
Old Jun 27, 2011 | 01:53 PM
wrd1972's Avatar
Why not call AI and ask them since you are using their custom spec cam? Are you using their heads too?
quik95lt1's Avatar
I'd run the PAC 1218's on it personally but give AI a call they will direct you in the best direction....
Old Jun 27, 2011 | 02:00 PM
Verz's Avatar
I have the LE version of that cam and im running patriot golds and so far so good
Old Jun 27, 2011 | 02:56 PM
AZ2ENVY's Avatar
Id do the PAC 1518s personally
Old Jun 27, 2011 | 03:30 PM
Camaroking1996's Avatar
ZL1LT1 what heads and cam are you using?
Old Jun 27, 2011 | 03:33 PM
AZ2ENVY's Avatar
AI 200cc heads and a Comp XE 233/239 .601 .610 111lsa Custom Grind
Old Jun 27, 2011 | 03:36 PM
Are the PAC 1518's the springs that come with the heads or did you put them on yourself?
Old Jun 27, 2011 | 03:37 PM
AZ2ENVY's Avatar
I put them on myself .
Old Jun 27, 2011 | 03:40 PM
Why did you switch out the ones from the 200cc heads?
Old Jun 27, 2011 | 03:48 PM
95mysticta's Avatar
Im running the PAC 1518s on my AFRs.
Old Jun 27, 2011 | 04:06 PM
What makes the PAC 1518's better than the other springs out there?
Old Jun 27, 2011 | 06:35 PM
trilkb's Avatar
verz, when you say golds which do you mean?
OP, If your running oem heads with stock valve seats remember that installed height will be MAX 1.750. Some places may tell you to install such and such springs at 1.780, and unless you machine the valve seats/heads you cannot do it. Just a little tid-bit of info that i wish someone gave me befor i wasted time and money!
Old Jun 27, 2011 | 11:54 PM
Wicked94Z's Avatar
I wouldn't install any 1518 or similar beehive any higher than 1.74. I like very few hydraulic roller springs installed any higher than 1.78. My personal springs are setup at 1.84 and I have over .690 lift on both sides.
Old Jun 27, 2011 | 11:56 PM
Wicked94Z's Avatar
They're nitrided and are basically indestructible and very long lasting in a correctly setup valvetrain. They're old school tech now IMO, there's a few other beehives nowadays that blow them out of the water. For the OPs application a 1218 or 1518 will suffice.
Old Jun 28, 2011 | 07:44 PM
Wicked what springs would you say that could blow the PAC out of the water
Old Jun 28, 2011 | 09:47 PM
Wicked94Z's Avatar
Other PAC springs and a Manley spring. The most you can get out of a 1518 is ~150/340 with .610 lift and that's installed real tight. I can do ~165/385 or ~165/375 with drop-in replacements for the 1518 at the same price. Or if you want to go real radical with the lobe profile I have a ~190/420 spring that will drop-in with a custom set of spring seats to work with stock length valves. Cost there is about 100 bucks more for both the springs and custom seats. All offer better valvetrain control than the popular dual springs on the market, 1518s are just a little light on pressure for more aggressive cam combinations.
Old Jun 28, 2011 | 10:16 PM
What Manley springs are you exactly talking about?
Old Jun 28, 2011 | 10:21 PM
Wicked94Z's Avatar
I've done alot of research on this stuff and don't feel like giving out info on a site I don't sponsor, I have an sponsorship on LTxtech.com if you'd like some more information
Old Jun 28, 2011 | 10:26 PM
Can u pm me the info?
