Can we swap out our stock LT1 rocker arms for 7/16 studs without machining??
At one point I had read somewhere that our stock rocker studs are 7/16 on the bottom and 3/8 on the top. And that if we wanted 7/16 on top and bottom it was as easy as a swap out with no machining. But maybe I'm wrong. Plz share your thoughts.
Originally Posted by solid95z
Yes you can swap them. The bottoms of the rocker studs are the same on the 3/8's and the 7/16's. Just take the 3/8 out and screw in the 7/16.
Originally Posted by Gangly
not sure if stock rocker arms will fit over the 7/16th stud but you will definately have to buy correct fitting rocker arm nuts for the wider studs.
I haven't bought the rocker arms yet becuz of that. So that's ok basically we can't mix rocker arm sizes. But we can swap our stock 3/8 studs for the 7/16 studs without machining!!
When ordering them I'm guessing they should be basically rocker arm studs specifying 7/16 top and 7/16 bottom. Phucken great news, thanx a million.
Oh that isn't a water jacker behind it right?? or should I have to pull a water plug when swapping?? I'll probably be able to tell when I pull the valve cover off but curious now.
No they won't. You will have to get 7/16 rockers for the 7/16 studs.
woah wait a minute. What do we have stock??? Isn't it 3/8 top and 7/16 bottom??
Allowing us to swap to 7/16 top and bottom.
Brett your saying your running only 7/16 top and still 3/8 bottom??? so our bottom is 3/8s????? then we'd be fooling ourselves in thinking it was a real 7/16 no??
I thought 7/16 is both top and bottom or there wouldn't be any added strength?? U sure that's what you got??
Top is for the rocker arms.
Bottom is inside the head.
