first time to the track
Old Aug 6, 2011 | 04:25 PM
jasonz28camaro's Avatar
Default first time to the track
so i went to the track last night for the first time. NEED PRACTICE!!!
i ran the 1/4th with 315 NT05s (street tires, not DRs) and could not hook off the launch, nor through any of 1st and some half into 2nd. (theres no such thing as feathering with these **** tires!!)
I pulled off a 13 flat @ 110, is this somewhat expected with no traction and the motor built for boost and not running boost?
i want to go back next friday with DRs and see what it can do, any guesses??
Old Aug 6, 2011 | 04:34 PM
Lawhead's Avatar
Sounds about right for what you have what kind of 60 foots where you getting???
Old Aug 6, 2011 | 05:08 PM
Dave357LT1's Avatar
Why in the blue hell do they cut the sigs out in the mobile version? Go get some r's if you got a ten bolt or mt's if you got a after market rear.
Old Aug 6, 2011 | 05:14 PM
transbird95's Avatar
Congrats on your fist passes man! It's always depressing to see your first time slip isn't it. It takes practice, then more practice and even more after that. If you get sticky tires and a decent launch, I would bet you could get really low twelves by going off your mph. Good luck.
Old Aug 6, 2011 | 05:22 PM
2.169
sorry left out the 2800 stall in my sig, updated now.
Old Aug 6, 2011 | 05:24 PM
I have the stock 10 bolt with 3:42s and aftermarket rear suspension, LCA/RB, and PHR.
Old Aug 6, 2011 | 05:29 PM
Dave357LT1's Avatar
Just get some 555r's i cut a 1.75 60' with boltons
Old Aug 6, 2011 | 05:36 PM
i bet, i have had a couple of pairs of those 555r in the past until i hydroed in rain and went into a ditch... now that i have the new motor and the spinning at the track i deffinently will be getting some DRs and going back to the track next week.
I purchaced a gun the other day and went and shot it, like you should right??? so i figured i need to go take my car to the track and now im addicted.
Old Aug 6, 2011 | 06:05 PM
Dave357LT1's Avatar
U purchaced a guy? Lol how was he?
Old Aug 6, 2011 | 06:29 PM
gun lol.
Old Aug 6, 2011 | 07:20 PM
TAEnvy's Avatar
Anything done to the top end? Heads Cam?
Old Aug 6, 2011 | 07:40 PM
Lawhead's Avatar
Le h/c/i
Old Aug 6, 2011 | 08:42 PM
Dave357LT1's Avatar
If it was a a.i. combo it would be in the tens. I kid
Old Aug 6, 2011 | 09:14 PM
LSWHO's Avatar
12.2 if you hook with no changes.
You should be able to squeeze out a few more mph and hit 11s in actuality.
You should look into the Density altitude when you run. It's a good gauge for how your car is really performing.
Old Aug 6, 2011 | 09:24 PM
AR15 guy's Avatar
What 1/8th mile time is a 13 flat?
Old Aug 6, 2011 | 09:45 PM
From one of my old time slips that i ran 13.076 my 1/8th mile was 8.511
Old Aug 6, 2011 | 09:49 PM
LSWHO's Avatar
Sounds like you had a stock stall at the time.
Old Aug 6, 2011 | 09:51 PM
Yuppers I shoulda said it can vary from different set ups but that's what she ran.
Old Aug 6, 2011 | 11:34 PM
AR15 guy's Avatar
I ran 8.68 with 3.73s, auto, headers and cai with my old z28. So with a stall and traction you should do better for sure. Get some sticky tires and see what it has.
Old Aug 7, 2011 | 02:00 AM
TAEnvy's Avatar
MPH seems a little low even considering the low compression. Then again Im used to M6 numbers but even considering your an A4 Id think its a little down on power. Got any more specs for us?
