Car feels slower than I should be
Old 08-11-2011, 02:33 PM
LT1Air's Avatar
Default Car feels slower than I should be
Alright so I have had my car for a little while now and over that time i have gotten Longtube headers, catback exhaust, 4:10 gears, and a tune. and my car doesnt feel like it should with all that done. what could be the problem. as far as i can tell the car is runnning nearly perfect. never has any hard starts, never cuts off,doesnt missfire, no signs of anything wrong...except it being really slow
Old 08-11-2011, 02:47 PM
LSWHO's Avatar
Run it at the track and check your plugs.
Old 08-11-2011, 02:52 PM
trilkb's Avatar
drive a 4 cyl honda for a week, get back in it.
sad to say but, your just used to it.
Old 08-11-2011, 02:57 PM
Lawhead's Avatar
False knock from the headers hitting some where? only thing I can think of that you would not notice would be it picking up false knock
Old 08-11-2011, 03:07 PM
Badazz 97 TA's Avatar
Well, only way to tell, take it to the track and see what it runs, race another LT1. take a video of the speedo at full throttle and post it up. Based on your very specific description, no one is gonna be able to tell you anything or help. dont know what you want really....
Old 08-11-2011, 03:23 PM
defaultexistence's Avatar
It's slow because it's an LT1 ..
Old 08-11-2011, 03:24 PM
Mystery Bird's Avatar
When's the last time it had a tune up? Fuel filter plugged, dirty MAF sensor, weak O2 sensors, air filter...
Old 08-11-2011, 03:43 PM
WS Sick's Avatar
You never know until you time it.
Old 08-11-2011, 04:54 PM
96TransAmboosted's Avatar
This is just funny.... you don't know nothing till you time it.
ahritchie's Avatar
OR dyno it....You could/should get a dyno tune anyway with your mods....that will tell you (and the tuner) A LOT about the condition of your motor. My cam only LT1 was a turd on the dyno (241 RWHP)....but after doing a leak-down test showed no issues...put in new plugs and BAM! 311 RWHP with just new plugs! Don't forget the simple little things....they can and do make all the difference in the world.
Old 08-12-2011, 04:00 AM
LT1Air's Avatar
the plugs are recently new from when i put the headers in. fuel filter could need to be replaced. it only has 62,000 miles on it
and at the track i could only get it to run 13.6 at 104mph
Old 08-12-2011, 04:37 AM
lt1-xjs's Avatar
LS1Tech 10 Year
Looks good for exhaust, gears and a tune. Although with that trap speed you should be well into the 12's.
Old 08-12-2011, 02:24 PM
boostedlt1's Avatar
idk about WELL into the 12's at 104... maybe lower 13's.
also depends what his 60' was. bad 60' could've helped his trap speed
Old 08-12-2011, 02:48 PM
lt1-xjs's Avatar
LS1Tech 10 Year
If I can do it at 3900 lbs, an F-body should be in the 12.5x range. He may of had a bad 60' but that's why they make D/R's and suspension parts.
Old 08-12-2011, 03:39 PM
LSWHO's Avatar
104 is enough for the average LT1 to hit 13.0
You could hit 12.5@104, but that would take a HELL OF A GOD DAMN LAUNCH.
I don't know where you get off acting like mid 12s should be normal for that trap.
Old 08-12-2011, 10:23 PM
yeah 104mph is like 13 sec at best.
Old 08-13-2011, 02:13 AM
LT1Air's Avatar
reguradless i should be hitting lower 13's on street tires shouldnt it? all the suspension mods i have done are lower rear control arms last time i ran i blew me carrier. i replaced with a new eaton posi unit but idk if it will hold on drag radials on the track. not trying to blow my rear again anytime soon
Old 08-13-2011, 05:41 AM
lt1-xjs's Avatar
LS1Tech 10 Year
I've run 12.8x's @ 104 for so long now, it just seems normal to me.
Old 08-13-2011, 07:28 AM
96capricemgr's Avatar
I would say you have something holding the car back up top then, I agree with those saying 104 is good for low 13s.
Far as the OP I am NOT a blind fan of dyno tuning as most are. My car is not dyno tuned and seems to work OK. The tune may be worth looking at though, just because it is tuned does not mean it is tuned well, even if the tuner is a good one mistakes happen and some of the popular tuners are not consistently good. One in particular occasionally gets one or two cars that will be noticed right and completely screws up a LOT more.
Old 08-13-2011, 07:47 PM
fbody93's Avatar
Get some et streets or drag radials. I take it you have a t56?
Quick Reply: Car feels slower than I should be
