Pickup bolted to oil pump (pic), still tack weld?
Haven't torqued the pickup down fully yet as you can see here but is it still necessary to tack weld the pickup? Also, I hope the space between the pickup and the pan is right since it's obviously not adjustable.
![](http://img.photobucket.com/albums/v222/robkoz/oilpickup.jpg)
Lol its bolted on, there is no need to tack it as long as you loctite the bolts. I only tack the press on pickups.
I understand the whole "better safe then sorry" thing, but that is completely unnecessary.
I agree. Seems the idea of bolting it on would do away with the need for tacking.
no no no, don't weld the oil-pump together... just the pickup to the pump. Either I was confused or all of us were. I always thought it was one of the 10 comandments of building an engine, its like the crank hub, it's pressed on and look what happens to them...
when i used mine with my maroso pan it was a little tricky but it went on. I know ill probably catch **** but im going to run this one with the stock pan on the new build. It measured out to be the right hieght so im going with it.
