View Poll Results: F/I on 3.48" stroke or N/A stroker with N2O?
I'd rather have a nitrous 383/396/409
13
65.00%
I'd rather have a turbocharged or supercharged 350/355
7
35.00%
Voters: 20. You may not vote on this poll
Forced Induction or a Stroker with nitrous?
Just thinking about it earlier... would you rather do a Forced induction setup, or a big cube setup with nitrous? I think I'd go for the normally aspirated choice... let's hear you guys' opinions.
I know plenty of guys would say both, so would I... but let's pretend you only have the money for one... which would you choose?
I'm all about a Turbo 355. That was my plan actually until my stock shortblock crapped compression on two pistons. Now it's just going to be a paltry 355 with a nasty custom cam.
Are we looking at a Daily Driver or a All out race setup?? or are we just looking? Big cube set-ups with nos can be wicked!!! But on the other hand A BIG Turbo on a 8:1 comp. small block can be just as wicked and lighter too.
Im in for more displacement and NA w/ solid roller cam, and high flowing heads. Seems like more of a challenge then forcing air, Although, I am into the squeeze when I cant reach the numbers I want on the track. Done the Turbo route and blew my motor on 12 psi. On top of that it was just too much of a hassle to find room for it and at the same it was hard to drain the oil from the turbo. It screamed on 12psi until it blew up. Story was that I wasnt Intentually trying to run 12 psi, I had my wastegate set at 6-7psi and someone had closed my wastegate completely
. Before I knew it, It didnt last 1 pass on 12 psi. I blew the head gasket and fried the piston rings.
